![]() Join Date: Dec 2009
S13 front wheels are not centered
Hi, i've heard that some 240sx had this out of the factory where the front wheels would not be centered causing one wheel to be deeper in the wheel well. My s13 has the same situation. Is there a way to fix it or alter to where both wheels are spaced aqualy? w/o using spacer only on one side.
Thanks! |
![]() Join Date: Jun 2003
Trader Rating: (129)
why would you possibly just happen to have an s14 control arm on one side????
#4 | |
OP, the thing you are talking about, as far as i know, is for the rear on s13's. The rear panels aren't symmetrical in a way that one side will look more flush than the other even though the alignment settings and everything can be the same for both sides
street dancer. |
#6 | |
![]() Join Date: Apr 2010
i was just browsing on the google about the difference from s14 vs s13 front spindles. anyone has more input for this? i understood that the s14 are bigger, correct me if im wrong. Im talking about 4lug ones only.
ok, i just noticed that wheel coilover clearance on pass side is 1mm lol, drivers side was about 10mm. also my flca are both s13, i confirmed that by comparing to s14. no can anyone tell me if its the knuckle thats different or hub?
#11 | |
![]() Join Date: Nov 2005
S14 four and five lug spindles are exactly the same, and they're not compatible with S13 ball joints, so I highly doubt that's it. |
heres's what i got:
pass side, pay attention to camber plates drivers side, look at the camber as well: i don't know what the hell is goin on. Last edited by sodel_s13; 05-18-2011 at 06:34 AM.. |
