actuator connection??
I know the actuator is suppose to connect to the cold pipe. But my cold pipe doesnt have a nipple for a hose to fit in? Should i just drill a hole in the hose or something. Or can i connect the actuator to the intake?
what engine is this for? ya you can connect it to a vacuum line of the throttle body. youll actually see one or maybe even a few more psi of boost due to the pressure loss on the intercooler system when you move it to the intake mani area.
I have a sr20det. I didnt know you can connect it to the vacuum line on the throttle body. Thats pretty far from the actuator. Maybe ill try it. Due to the actuator not connecting to anything am i gonna have boost spike?
