Help me identify this bolt/seal PLEASE
Hey guys i have a 1997 240sx and i got coolant leaking from this bolt/seal
Anybody know what bolt or seal this is? I would appreciate the help. https://mail.google.com/mail/u/0/?ui...&sz=w1096-h647 |
![]() Join Date: Jan 2010
Trader Rating: (26)
Maybe better images would work best. It almost looks like you're pointing at the intake manifold bolt unless you're talking about the freeze plug-esque item lower on the motor.
![]() Join Date: Apr 2014
First off this belongs in the small questions thread!
I skimmed through my fsm for you but couldn't find much info about it. If you know it's leaking coolant my best advice would be to remove the plug, inspect the threads for damage, if it looks okay reinstall with sealant or Teflon tape and torque to 25 ft/lbs. Be sure to bleed the coolant system properly. Don't see why that wouldn't solve your problem, best of luck to you! |
