| South Central States Arkansas, Kansas, Louisiana, Missouri, Oklahoma, and Texas. |
I hope all you drifters are ready for this event!! It will be epic for the 915!!
![]() In conjunction with the Super Tunerz ShowOff car show, True Street Industries, LLC will be Bringing Drifting back to El Paso's Drift house, Cohen Stadium!!! September 8th 2012 "Roll in" for Drifters will be from 10am - 11am Tech inspection will be from 11am - 12pm Drivers meeting will be held at 12:30pm First Practice will be from 1pm - 2pm Second Practice will be from 2:30pm - 4pm Intermission 4pm - 5pm Drivers meeting will be held at 5pm Competition Round 1 will be from 5:15pm - 6:15pm Competition Round 2 will be from 6:30pm - 7:30pm Competition Finals will be from 7:45pm - 8:45pm All Drivers -Must- pre-register at True Street Industries, LLC prior to September 6th 2012. Driver entry fee $40.00ea Pit crew passes (limit 2) $10.00ea $500 GRAND PRIZE!!!! Pit Crew must Roll in with Driver. No additional persons allowed in Pit area. Times are subject to change. Tech inspection requirements are attached to registration form and waiver. All inquiries must be directed to True Street Industries, LLC 1421 N. Lee Trevino Suite A-6 El Paso, TX 79936 915-591-8119 [email protected] True Street Industries, LLC Super Tunerz Showoff Tech Rules Basic broken down Tech Inspection Requirements are. Helmet is required. All Lugnuts must be present and torqued properly Battery tie downs/brackets must be used to secure the battery. (no string/rope/bungee cords) Exhaust must Exit the vehicle behind driver. Coolant overflow/reservoir must be installed. Crankcase ventilation must be installed (Stock/aftermarket/Catch Can/Custom) Seat belts or Harnesses must be Present and installed properly. Fuel/Oil/Radiator Caps must be present. No Fluid leaks. (oil/coolant/fuel) No open toe shoes. No Shorts (full length pants/jeans must be worn) No tires already showing chord with be allowed to re-enter the track. More in depth waivers and tech rules will be given to the driver upon Pre-registration. There will be no registering the day of the Event. Call 915-591-8119 for more info or questions. |
