Old 09-28-2010, 07:44 PM   #1651
GripTerror
GripTerror is an unknown quantity at this point
hah i was just gona post in this thread and ask did it did and whats up to all. No news for a while. I guess its winter coming No nws from powered by max or def lol
GripTerror is offline   Reply With Quote
Old 09-28-2010, 09:16 PM   #1652
PoorMans180SX
PoorMans180SX's Avatar
Yeah, I've been super busy, and haven't done the editing to the OG post that I've wanted to.
I'll try and get on that.
Old 09-28-2010, 11:19 PM   #1653
95KA-Turbo
95KA-Turbo's Avatar
My new spindles have been welded, I just have to track down a 5/8" drill bit and figure out a way to use the drill press to drill out the tie rod spot and use the taper bit for my ball joint spot and I can post up sweet suspension porn.
Instagram - SJKnoop
Old 09-29-2010, 05:23 AM   #1654
Slidin' Sam
Slidin' Sam's Avatar
Slidin' Sam is an unknown quantity at this point
Originally Posted by DC Dan MAX USA View Post
I have made myself a note to contact you when they arrive.
Domo sir! Much appreciated!
Sweet! I LOVE suspension porn! It's almost as good as real porn!
Slidin' Sam is offline   Reply With Quote
Old 09-30-2010, 06:13 AM   #1655
GripTerror
This is pretty creative, it was on a Volvo though:
Old 09-30-2010, 06:40 PM   #1656
DamienM
DamienM is an unknown quantity at this point
Cool idea.. More reactive steering and increased steering angle
DamienM is offline   Reply With Quote
Old 09-30-2010, 08:54 PM   #1657
mmdb
mmdb's Avatar
mmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymore
Nice find! I like how you can change ackerman along with roll center.
.25 till 3
mmdb is offline   Reply With Quote
Old 09-30-2010, 10:10 PM   #1658
Def
Those holes look like they're in a straight line out from the ball joint, so they wouldn't change the ackerman at the different settings. Since they go straight to the stock steering arm hole, looks like the ackerman is held the same.
DEFSPORT
Old 09-30-2010, 11:16 PM   #1659
95KA-Turbo
95KA-Turbo's Avatar
I wasn't going to post these up because my front suspension is all out of whack in these pictures, but I figured why not.
These are NOT the spindles I am going to be running, I just slapped everything together so I could get the car on and off the trailer.
Underside shot...
You can see how out of whack my alignment is, haha.
Instagram - SJKnoop
Old 09-30-2010, 11:30 PM   #1660
Def
What brakes are you running? I didn't think that long of a shank would fit on a stock spindle before hitting the rotor.
DEFSPORT
Old 10-01-2010, 12:05 AM   #1661
95KA-Turbo
95KA-Turbo's Avatar
I am running Q45 brakes.
It was hitting just barely so I had to grind a little of it down, then I made he discovery tonight that it hits at full lock, so I am going to have to do some more grinding. I am not sure if I will be able to add the 10mm spacer without making it hit even more.
I am thinking about making some 3mm spacers to put behind the rotors to push them out a tiny bit. Do you think I will need to reposition the calipers too?
Instagram - SJKnoop
Old 10-01-2010, 12:50 AM   #1662
Def
Yes. In fact, I'd just cut the shank down some vs. spacing out your brake caliper. That just sounds like a bad idea. Could work in practice, but having to move the caliper out, and then having a ghetto setup for a few more mm of arm angle.... I wouldn't do it personally.
DEFSPORT
Old 10-01-2010, 12:08 PM   #1663
olah.inc
olah.inc's Avatar
olah.inc will become famous soon enougholah.inc will become famous soon enougholah.inc will become famous soon enougholah.inc will become famous soon enougholah.inc will become famous soon enough
Driftworks will soon release the geomaster hub knuckles MK2...
...A few geometry tweaks to slightly improve the already insane amounts of lock.
The major change is that the rears will also work with the drum brake setup from S13/R32/R33 etc...
olah.inc is offline   Reply With Quote
Old 10-01-2010, 03:31 PM   #1664
az_240
az_240's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
^Any more info or pics? I looked on their website but only saw the older style stuff.
Are they still using polyurethane in the rear upright?
Old 10-01-2010, 10:22 PM   #1665
!Zar!
!Zar!'s Avatar
Alright geometry bro's, I decided it was time to put my alignment above my wheel fitment game.
So I threw on some Kazama toe arms and some PBM Ruca's and tried to get 1.5*camber with 0 toe.
After threading out the ruca, it came out to an unsafe length, so I figured I would raise my car 1.5" (UGH), even after that, closest I could get to a safe distance was 3*.
WTF? I mean I could raise my car another inch, but it already looks like a pile of fucking dicks.
Yes, it is installed correctly, and no, my subframe isn't bent or anything.
So wtf.
Thoughts? Only other thing I could think of is trying a different set of ruca's, or cutting/shortening my lca's.
Old 10-02-2010, 08:43 AM   #1666
C. Anderson
C. Anderson's Avatar
C. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond repute
Subframe risers will help a little. Other than that I don't know because my pbm stuff will let me run +15 camber if I wanted and I'm slammed.
C. Anderson is online now   Reply With Quote
Old 10-02-2010, 12:19 PM   #1667
nieko
nieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfection
Guessing you have stock traction rod huh?
When you slam your car that rod needs to get lengthened too to get the goemtry right again.
go buy a traction rod
nieko is offline   Reply With Quote
Old 10-02-2010, 12:28 PM   #1668
thefro526
thefro526's Avatar
Nieko corrected me, I must've miss read the post I saw. Whoops.
thefro526 is offline   Reply With Quote
Old 10-02-2010, 02:22 PM   #1669
nieko
^^^^^^^ what you read was the OPPOSITE of the problem.
The guy that had the issue had a slammed car but wanted MORE camber and the rod was maxxed in.
Get at traction rod, make it longer, ta da.
Old 10-02-2010, 03:26 PM   #1670
!Zar!
!Zar!'s Avatar
Yeah, I want more positive camber. I'd like to get it down to 1.5, which shouldn't be a problem one would think...
This is the first car I've had toe and ruca's, without traction rods. I guess if I bought some, or added 10cm or the stock ones or something that would help a little?
I drove the car with the, formula-d ride height, and I can see why a lot of people have risen their cars. It was so much more predictable, stable, and accurate.
But it is also a lot uglier.
I still have the stock subframe; it's an s13. So I guess an s14 subframe along with raising it would help as well.
Guess it is time to stop the whole slammed drift car thing, and get on to the functional awesome handling drift car.
Damn it all.
Old 10-03-2010, 03:22 PM   #1671
olah.inc
olah.inc's Avatar
i think more info`s will come in 3 weeks or so
Old 10-03-2010, 05:12 PM   #1672
!Zar!
!Zar!'s Avatar
Speaking of raising cars, in theory, all I needs to be done in order to correct suspension geometry once again is to have the arms level front and rear? Of course, matching the tie rod and tension rod angle.
Old 10-04-2010, 01:33 PM   #1673
DC Dan MAX USA
DC Dan MAX USA's Avatar
Trader Rating: (79)
DC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond repute
Feedback Score: 79 reviews
LCA's are at the factory getting produced, and tie rods are finished and stock is on its way.
I got some good track time on the prototypes and I love them! production parts will be much better than these.
So wtf.
my thought is that this thread is about having the best of both worlds, I dont see why you cant have proper alignment and wheel fitment
perhaps you have the version 1 RUCA which is shorter while version 2,3,4 is longer?
MAX would be 20mm exposed large threads and 30mm exposed small threads.
This means you could move the small threads of the end joint out farther than the double adjuster (because the end joint is really long).
safest would be about 18mm exposed large threads and 16mm smaller threads. This comes from having the adjuster in the shortest position and only adjusting the adjuster, it leaves lots of overlap and is really strong.
correct SFR will help. they move the camber more positive.
you probably have the newer version and he likely has the oldest version.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate.
Order Inquiry: IM me your real name and paypal address.
Thanks for your business!
DC Dan MAX USA is offline   Reply With Quote
Old 10-04-2010, 03:35 PM   #1674
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Damn it all.
*sniff* This brought a tear to my eye. Join the darkside!
Old 10-05-2010, 04:58 AM   #1675
Slidin' Sam
Dan, any word on pricing for the LCA's? Also, please don't forget to shoot me a PM when the tie rods are in stock so I can order them from you! Thanks!
Old 10-05-2010, 07:43 AM   #1676
SoSideways
SoSideways's Avatar
So the PBM FLCAs will still have both the inner and outter rod ends in bending?
I was really hoping that wasn't going to be the case...
In any case, quick update.
Car is on the ground (has been since like last Friday actually), and I've driven it around the block a couple of times.
Made some adjustments last night, and the last lap around the neighborhood felt good, so tonight I may put the rest of the car back together and actually drive it on the road for a proper road test.
Really would like to do a newspaper pull on the wheel arches towards the rear of the car, as I am rubbing the tires on both sides hitting bumps. Guhhhhh...
Will post pics of fronts before I put the front bumper back on and such.
Old 10-05-2010, 11:30 AM   #1677
!Zar!
!Zar!'s Avatar
Yes? A little lower? Eh?
I just want to see my roll center like a fat man tryin to see his dick.
Old 10-05-2010, 12:16 PM   #1678
PoorMans180SX
How would the inner heims be in bending? They rotate vertically on the inner bolt.
Every aftermarket front arm uses heims like that on the inner.
Driftworks geomaster hub knuckles V2 article:
http://www.driftworks.com/2010/10/geometry-nirvana/
Old 10-05-2010, 07:39 PM   #1679
DC Dan MAX USA
Trader Rating: (79)
No pricing until just before they arrive. Sure thing.
Although the prototype parts are that way, and work just dandy...
The outer bearing on the FLCA is fully enclosed on the production version.
right! the inner is not the issue, its all the front braking torque on the outer
Old 10-05-2010, 10:05 PM   #1680
codyace
codyace's Avatar
Trader Rating: (58)
The Ultimate Handling Guide Part V: The One Unforgivable Sin, Overlowering Your Car
Just a funny/nice/informative little post by Mike Kojima over at MotoIQ about Roll Center and the sort. WHile most of us are beyond it, it's a nice thing for those just browsing this thread for the first time, and wanting to understand the basics.
