Old 09-22-2008, 02:13 PM   #1
supermariokartdrift
supermariokartdrift's Avatar
supermariokartdrift is not welcome here anymoresupermariokartdrift is not welcome here anymoresupermariokartdrift is not welcome here anymoresupermariokartdrift is not welcome here anymoresupermariokartdrift is not welcome here anymoresupermariokartdrift is not welcome here anymoresupermariokartdrift is not welcome here anymoresupermariokartdrift is not welcome here anymoresupermariokartdrift is not welcome here anymore
Exclamation KA problem cranks & wont stay on
I just got the problem last night. I was driving and my e brake came on full bright with the battery light dim. Tried to restart after getting home and it starts, but the idle drops and shuts off. It will only stay on if i give some throttle to keep it from dropping. It will stay on if I ease of the gas, but idle stays low. Can anyone give any suggestions?
supermariokartdrift is offline   Reply With Quote
Old 09-22-2008, 02:56 PM   #2
blackrms13
blackrms13's Avatar
blackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfection
Send a message via AIM to blackrms13
holy fuck im having the same exact problem...
when the brake light come on theres a buzzing noise as well...i duno if urs is doing the same
blackrms13 is offline   Reply With Quote
Old 09-22-2008, 03:33 PM   #3
supermariokartdrift
no buzzing but e brake light stays on after its disengaged
Old 09-22-2008, 09:00 PM   #4
s13playa
s13playa's Avatar
s13playa is an unknown quantity at this point
yea, same here.
edit: found this #/f/tech-talk/213166...ght-stays.html read the last few posts...
s13playa is offline   Reply With Quote
Old 09-22-2008, 09:04 PM   #5
WangonwWarrior
Location: Amerika24 alabama: Where if your not first..... your last
WangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant future
Have you tested spark plugs, injectors, MAF, fuel filter, vaccume hoses, air filter, PCV? It is probably one of those.
WangonwWarrior is offline   Reply With Quote
Old 09-22-2008, 09:18 PM   #6
blackrms13
blackrms13's Avatar
i replaced that vacuum(sp?) hose that connects the valve cover and the intake tube, and that two sensor plug thats at the back of the engine, between the end of the valve cover and the firewall and adjust the idle screw a lil bit, and now its staying on, but still dips low when i start it, this other dude suggests me to clean the EGR valve and the MAF
s13 with 95 KA with a s13 auto ecu(#27)
still having that ebrake problem tho
hope this will help
Old 09-22-2008, 09:25 PM   #7
s13playa
s13playa's Avatar
well yea, a dirty egr valve will affect idle... but if your e-brake and battery light are still on its most likely the alternator...
Old 09-23-2008, 12:59 AM   #8
supermariokartdrift
thought it might be the alternator. will check the other suggestions. thanks for the input.
