![]() Join Date: Jan 2008
Tomei KA24DE Adjustable Cam Gears
Apparently they are offering these now. I'm considering going this route instead of the JWT gears but figured I'd see if anyone's already picked up a set and what their thoughts are.
https://www.tomeiusa.com/?p=15548
86 300zx/90 240sx/97 240sx/96 LS400/03 350z -Shake N' Break Racing- |
#2 | |
![]() Join Date: Jun 2003
Trader Rating: (129)
http://bluemoonperformance.com/ |
![]() Join Date: Sep 2014
Isn’t tomei USA a spin off of the original tomei? I wonder what the quality difference is, that’s why tomei (og) drooped tomei USA to begin with :/
My main concern is whether or not the sliding adjustment is at risk of moving unexpectedly. At the same time that feature is pretty nice so long as it holds.
#5 | ||
![]() Last edited by brndck; 12-19-2019 at 08:37 AM.. |
![]() Join Date: Mar 2008
That's what I was thinking when I first saw the design. The bolts have less leverage in keeping things from moving on the small KA cam gears, but there are 6 of them. I'm sure it's fine, and adjusting them looks pretty easy.
Hence my use of the word "unexpectedly". I would not expect that its going to move with 6 bolts but its still a possibility.
At that point, it’s operator error, not a flaw with the part.
Probably true but hard to say for sure without actually looking at them. Like I said, its my main concern but I also see it as an unlikely failure. I'd rather be over cautious than lose an engine.
#13 | |
SR20 tomei gears have 6 bolts and I've never heard of anyone having one come loose before. ![]() |
There's just more forces involved with the smaller diameter cams sprockets on the KA. It's like when you're in a high gear on your bicycle. The chain is under higher stress under acceleration. It's most likely why Nissan designed the upper timing chain to be dual-row.
It's probably fine, but I'd be crunching some numbers if I had stiffer valve springs and a high-hp KA-T. I don't know, maybe I'm just paranoid. |
