ok well im getting ready to purchase my red top and wondering if anybody has some sort of list for a basic swap. im not going all out but do want to get all the small things like the heater hose and frontmount intercooler. i kind of want to order everything this way i can do the swap in one weekend. thank for your helpps if you have used part that i will need pm me. thank again ![]() |
![]() Join Date: Apr 2010
Trader Rating: (38)
And you're asking for what? A list of what? Parts? Try google. How to/tutorial? Google. What else is needed including the engine? G-O-O-G-L-E.
ps if you have need any more help. try google. thank again ![]() |
Really is no part list. As you do your swap you will find things missing or thing that dnt fit. I bought a hole clip and still had problems with my swap took way longer then most swaps.
![]() Join Date: Dec 2005
I'll be nice... You will wanna make sure u have these things as some u will need to buy and some that may not come with ur "swap"
S13 SR radiator and hoses possibly t-stat Make sure the clutch fan is good and you will want to get a stock fan shroud Intake piping You said ur going fmic so you will need to make sure the piping works Spark plugs Power steering lines that will work (it's been a while so I don't remember if KADE ones work, I know SOHC ones don't work) Motor mounts and tranny mount (if ur swap doesnt have one) Wiring harness You may need to replace clutch, sensors, plugs, belts, gaskets, etc Downpipe Fluids (obviously) I dunno it's late, I'm sure I'm missing things. Anyone else care to add to the list? |
Also, 2 things not to forget on the turbo, 1) the anti backoff plate for the Turbo nuts (wasn't on my car when I got it, required about 12 hours work to fix) 2) the compressor inlet gasket (I couldn't find it on any exploded views, if it's not in a complete turbo gasket kit, check my "turbo bogging" thread for an OEM part #). Also, I'm not a fan of the spring reinforced rubber intake. There's a guy on ebay selling cast aluminium inlets with proper vacuum/ return connections, silicon couplers and K&N filter for $125. If you already have a cone filter, he'll work with you. I want to say he sold me the kit, sans filter for $85 shipped (it may have been $85+shipping). Finally, plugs== NGK BKR7EIX gapped to .028, and you'll need a 255 l/h fuel pump. |
Oh and one more thing I highly recommend that you replace a lot of the gaskets inside the engine it's a 20 year old engine so you can't assume that it's gonna be good to go, I would say rebuild it, but I don't know if you have experience with that sort of thing, if you don't and also have the money to pay someone else to do it, I would recommend it as it'll give u some peace of mind and also be better if you plan on adding power
