hi,
strange problem. everything worked fine first. suddenly the signals dont work at all. zero response, neither in the cockpit. but hazard lights work fine. really strange. already swapped the signal combo switch. but no good could the problem caused by the signal relay or the harzard switch? have to order from the usa and ship to europe.. so some tips would be nice. kind regards |
#6 | |
very very strange. also i got a summing sound near the coil wires when the fuse for the Rear Lights is in. WTF seems like i got a wire problem i have to check out ![]() first thing i had to do when i got the car was delete the gawd damn alarm system. maybe it has something to do with that. ![]() |
soooo had the EGI relay clicking as crazy
egi relay problem is def. a thing on google.. after several tries nothing works at all anymore. zero response when i put ign on. i hope nothing completely fucked up now. |
| 240sx, hazard, signal |
