![]() Join Date: Nov 2007
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
Need help asap:::vehicle speed sensor:::signal wire
1997 S14 KA(if that matters)
hookin up a greddy turbo timer. i have the ignition harness, so thats done. now i need to hook it up to the speed signal wire. i found the speed sensor on the tranny. I have two wires out of the sensor. -RED and -RED w/yellow stripe. which one is the signal wire??? |
Trader Rating: (18)
i checked out the harness that i bought. the ignition harness on the car has six wires. the greddy harness only has 4 prongs. they plug in, but its like there's two missing prongs.
i think thats why. ill ask someone local with a harness to see if i happened to get the wrong one. |
#6 | |
![]() Join Date: Dec 2002
The VSS signal wire is yellow/green, found behind the cluster or at the ECU. Same as nearly all Nissans.
Yes, or don't even use the harness and just splice in what you need.
