Old 09-07-2015, 09:35 AM   #1
ntcp8
ntcp8 is an unknown quantity at this point
s13 s13 drop knuckles and retain 4 lug?
i know most kits require 5 lug conversions but if I recall correctly I did find a thread where someone retained 4 lug using s14 or abs hubs or something along those lines. Now i tried looking for it but I cant seem to find that thread. Does anyone know what im talking about? or does anyone have a solution to running drop knuckles and maintaining 4 lug? im pretty sure the rears can be done but what about the fronts? any info would help... thanks
ntcp8 is offline   Reply With Quote
Old 09-07-2015, 10:24 AM   #2
ka-titties
4/5 lug hub has nothing to do with drop knuckles. You can run either one.
Old 09-09-2015, 11:15 AM   #3
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
It does and it doesn't. if the knuckles utilize s-14 sized spindle. Then you need s-14 4 lug hubs. If they utilize s-13 sized spindle, then you use s13 hubs.
S13 spindle is a smaller diameter then s14 spindle
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
