![]() Join Date: Nov 2007
Track Settings for Alignment?
Hey friends,
I will be going to Big Willow in about 3 weeks. I need a good alignment. I was wondering if anyone had track settings they recommend (not for drifting). I have a stock ls1 powered s13, coilovers all around, rucas and thats pretty much it...any input will be much appreciated...thank you guys |
![]() Join Date: Apr 2004
Frt:
-2.5 to -3.5 deg camber zero toe stock caster Rear: -1 to -2 deg camber 1/8-1/4" TOTAL toe-in The more tail happy you want it in corners the less toe-in you want to run in the rear.
![]() Join Date: Dec 2004
Trader Rating: (58)
Correct. I try to run 1/16th on each side...just a smidge. It's a total 'anti hoon' setting for any car making power...I love being able to power out of a corner without issue
I run the exact settings Def describes...it seems to have worked best for me to date
