| South Western States Arizona, California, Hawaii, and Nevada. |
era-1 drop drift knuckles S14 for sale
I bought these for $1350 new over a year ago. I tried fitting them on my car and with my 326 power coilovers and r33 brake caliper set up they just wouldn't fit. The brake caliper mounting points wouldn't clear the coilovers. I think it's due to the 326power coilovers extremely short design. Now my project has been put on hold and i'm needing some extra cash. I'm asking $1000obo for the front and rear knuckles and steering rack offset spacers.
5four1510seven772 call or text me if your interested. Thanks, Craig Era-1 Cast High Carbon Steel Front and Rear Drop Knuckles With Angle Spacers. Made from Molded Cast High Carbon Steel UNLIKE inferior product made using welded plates. Modified Ackerman for more steering angle. Lowers chassis 1.7in (43.18mm) front, 2in (50.8mm) rear. Corrects suspension geometry. Increases suspension travel. Decreases suspension binding. Increases traction. Provisions for Z32 e-brake. Used and tested by professional driver Walker Wilkerson in FD and Rob Primo in the FD Pro-Am circuit. Powder-coated finish offered in a variety of colors (custom finish upon request) Comes with high quality urethane bushings. Limited LIFETIME manufacture defect warranty on all Cast Knuckles and LIFETIME usage warranty on bushings. These are a direct bolt on affair for S14. S13 will require S14 hubs and ball joint. The kit includes front and rear knuckles as well as offset steering rack spacers. |
