Old 11-16-2016, 01:44 AM   #1
doridoridori
doridoridori is an unknown quantity at this point
S13 SR20DET simple mods
So i'm new to the SR world. I hope not to get too much of a hard time if what im asking has been covered before which I wouldn't doubt just couldn't find the answers i was looking for in the search. Been considering doing a SR swap (non s-chassis). I was considering on getting a S14 SR to start off with a T28 but a S13 SR T25 seems to have fallen into my hands rather cheap (import engine). I heard the stock whp was under 200whp. I would at the minimum would like 200whp but if i could be at a conservative 250whp would be nice. I've heard some people mention getting a S14 T28 on the S13 blacktop and I'm going to assume the internals are the same if not close between the S13/S14 blacktop variations aside from the VVT (correct me if i'm wrong). So my question is what can i expect from the stock S13 SR. On top of that if im trying to hit 250whp what is the most I can do with stock injectors, maf, ecu without having to go afermarket ecu and tune. I will have a walbro 255. Intake/aftermarket turbo mani help much also?
thanks in advance
doridoridori is offline   Reply With Quote
Old 11-16-2016, 03:22 AM   #2
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
there are so many threads covering this....
Old 11-16-2016, 07:17 AM   #3
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
op you literally could not have done LESS research.
please make best friends with the SEARCH button and refrain from making new threads till 2018
Old 11-16-2016, 10:14 AM   #4
doridoridori
Unless there is an issue with the search bar I typed in the same thing I'm asking about and I didn't find what i was looking for. Also Google searched but I didn't find those details, excuse me for asking 😑🔫
Old 11-16-2016, 10:17 AM   #5
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
https://www.google.com/webhp?sourcei...r20det%20build
Lying is bad mkaaaaay.
[email protected]
hanzbrady is offline   Reply With Quote
Old 11-16-2016, 11:07 AM   #6
cbeuglas
cbeuglas is an unknown quantity at this point
http://forums.nicoclub.com/hp-with-b...sr-t59344.html
Sent from my SAMSUNG-SM-G920A using Tapatalk
cbeuglas is offline   Reply With Quote
Old 11-16-2016, 09:07 PM   #7
doridoridori
Originally Posted by hanzbrady View Post
wasn't lying but appreciate the link.
Old 11-16-2016, 09:20 PM   #8
itsjustdaphne
itsjustdaphne's Avatar
itsjustdaphne is a well-known jackass
No need to go aftermarket ecu, you can get a mail order rom tune through rs-enthalpy.com
@ddaapphh | @spectuned
itsjustdaphne is offline   Reply With Quote
Old 11-16-2016, 10:05 PM   #9
derass
First result from Google, 220whp:
#/f/showthread.php?t=247317
Old 11-17-2016, 08:32 PM   #10
doridoridori
i've heard good and bad things about them. Is it safe to get a rom tune and just drive it from there or would i still need a dyno tune? (im assuming so)
Old 11-17-2016, 08:35 PM   #11
KAT-PWR
KAT-PWR's Avatar
Rom tune is fine. Rs Enthalpy changed hands many moons ago and I can't remember ever seeing a bad review since Martin took over.
MRP Manufacturing
Old 11-17-2016, 09:58 PM   #12
Jorgs_7
Jorgs_7's Avatar
Jorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really nice
GT28
CodyAce manifold w/external w.g.
JWT S4 cams
3" FMIC
850cc injectors / WB255
MAP based
standalone EMS
3" intake/exhaust
Some MLS head gasket
/best SR set up ever 350 WHP - 400 WHP
Jorgs_7 is offline   Reply With Quote
Old 11-17-2016, 11:00 PM   #13
DurtyD
DurtyD is an unknown quantity at this point
Originally Posted by Jorgs_7 View Post
GT28
JWT S4 cams
3" FMIC
MAP based
standalone EMS
3" intake/exhaust
Really want to do something like this for my sr, how much you think all that costed?
DurtyD is offline   Reply With Quote
Old 11-18-2016, 07:35 AM   #14
jedi03
I would guess about 4k as long as you do the work...used parts would save some money
Old 11-18-2016, 07:31 PM   #15
doridoridori
roger that im considering it, im debating on keeping the T25 or just looking for a S14 T28 but i'd like to retain the stock injectors
Old 11-19-2016, 11:24 AM   #16
jedi03
do the 28...you will be much happier
Old 11-19-2016, 12:37 PM   #17
gaz_moose
gaz_moose is an unknown quantity at this point
I would just fit,
FMIC
free flow exhaust
air filter
T28 off an s14 (a lot of import s14 and s15's came with BB t28's)
uprated fuel pump
1 bar of boost
some kind of ecu chip
98 ron ++++ fuel
that should see you at about 280hp which is the limit of the AFM and injectors.
a Z32 AFM and some s15 injectors and a gt28rs aka disco potato would see you at 250hp but you may aswell stick some 740's and a gt2871r or a gtx2867r and be near 400hp. a stock unopened SR will take 400hp providing its not knackered before you bolt it all on.
gaz_moose is offline   Reply With Quote
Old 11-19-2016, 07:42 PM   #18
TheRealSy90
TheRealSy90's Avatar
GT28
JWT S4 cams
3" FMIC
MAP based
standalone EMS
3" intake/exhaust
Or a TD-06 20g.
Such a good signature.
Old 11-19-2016, 08:32 PM   #19
Jorgs_7
Jorgs_7's Avatar
Got a decent amount second hand (AEM v2 for 700$, used GTX turbo)
I was around ~4500$
Old 11-19-2016, 08:44 PM   #20
doridoridori
Originally Posted by gaz_moose View Post
I would just fit,
FMIC
free flow exhaust
air filter
uprated fuel pump
1 bar of boost
98 ron ++++ fuel
badass thanks for the info man!
Old 11-21-2016, 09:52 AM   #21
scottie
scottie's Avatar
My setup:
GTX2867R
Codyace Cast Mani - Tial WG
Swaintech Coated
PBM DP
Custom Recirc 304SS w/Flex Section (into the divided wg side of dp)
Vibrant 90* elbow compressor outlet
**This setup combined with the PBM HMIC required only (4) couplers**
I will post again once reinstalled along with the mani cover and misc items. Supporting mods include:
Nistune
DW 950's
CNC'd Rail
AEM FPR
300zx MAF
300zx Fuel Filter
Splitfire Coil Packs
Greddy Profec B
Greddy Intake Mani
JWT S4 Cams
IG: @scotheocelot
Old 11-21-2016, 11:24 AM   #22
TheRealSy90
You better share what kind of numbers that setup makes! I need something to compare to haha.
