![]() Join Date: Jun 2011
Frying injectors! need help!
So to start off I have a built s13 red top sr20 in my s14 running off apexi power fc with the hand controller, when i got this car it was running rough only to find out cylinder 2 deatschwerks 550cc injector had gone bad, so until I receive a replacement I toss in 370cc q45 injectors and it runs GREAT! for about a day.... then fries cylinder 3 injector, I replace it thinking the used injector had gone bad. Driving the car a few hours later I park it and it takes a while to finally start, it smokes, runs rich, and is sluggish the whole way home. Same symptoms as before. So I pull the injector#3 plug only to find it doesnt change. Im really confused as to why my car is doing this, any help would be greatly appreciated.
![]() Join Date: Dec 2006
Check the wiring harness
only when harnesses are wired up incorrectly
harness could be shorted/rubbed through and grounded out somewhere.
Inspection of the harness would be a good start
if wiring is not an issue and ECU is fine then gonna have to chalk it up to shitty injectors
