![]() Join Date: May 2012
hey guys im desperate for your help. ive replaced the distributor rotor, was gonna replace the cap but got shipped the wrong one-___- im getting spark to the dizzy but it seems to stop there. what can i do? im praying to 8 pound baby jesus its just the ignition coil. im gonna try a spark plug test today. it cranks but wont start.
Crown and coke, love story in the making. |
no it shouldnt be, ive just recently replaced it. i had to jump start it for like a week cuz i couldnt find a starter in time . i even tried jumping it again and the tranny catches but it doesnt start. its gotta be a electrical issue.i replaced the dizzy rotor, im hoping it may just be the spark plugs or ignition coil
![]() Join Date: Jun 2010
I think they read the first post wrong. The engine is turning over but not starting. If it was the starter, it wouldn't turn over at all.
I would recommend taking off the distributor and making sure it is timed right first, that is assuming you took it off recently. If not, than take the cap off and make sure there isnt any damage like major markings, missing spring, or any missing parts in general. If you get spark to the distributor, I would guess the middle blade thing is damaged or something similar to that issue. Should be a super simple fix. Could help you more if you check for spark on the plugs just in general. If you have a skype, could help you quicker that way as well. Goodluck.
S14 KA NA two cylinders, 75whp limper |
dont wanna thread jack you bro but my friend is having the similar problem with his 240 only thing is his starts most of the time just at times it wont do it at night im assuming the temperature has something to do with it
![]() Join Date: May 2009
420-the temp sensor must be replaced.
f95- make sure its on tdc, adjust/check timing and dizzy its on proper firing position.
☆*Nissan-RPS13☆Nissan 350Z*☆ ☆*Toyobaru FRS☆Toyota XB*☆ ☆*o(≧▽≦)o*☆ |
