Old 08-20-2014, 07:21 PM   #1171
smellslikerubber
smellslikerubber is an unknown quantity at this point
also looking on other opions on where to go with the car from here? as far as motor work. what are good upgrades to start with? i want to get a good strong running motor before i go and try to drift the car. if that is what i decided to do with it
smellslikerubber is offline   Reply With Quote
Old 08-25-2014, 07:21 PM   #1172
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
Originally Posted by smellslikerubber View Post
s13
RB20
i have a mostly stock rb20. i just got it running strong but i still feel like it has a fuel issue. it has a walboro fuel pump and stock injectors. im looking to upgrade the fuel sytem and i want it to be top notch to where i only need to do it once. so im wondering what would be the best installs. 440cc injectors? or would something bigger be better. what would i need as far as fuel rail and lines? i also know i will need a FPR. im also started to look into the Greddy Emanage, would that be a good option as well? just looking for a good set up. i wanna make somewhere around 400hp when im done with the car. so suggetions and set up ideas are welcome
First off there are many things to consider when installing a proper fuel system. What is your HP goal and what are you going to be doing to the car. For most people with bolt-ons and moderate setups a walbro 255 will be enough to safely get you to around 450whp now if this car is going to see very high horsepower and or heavy track use you may want to look at a dual fuel pump setup and even a surge tank with dedicated power circuits,larger lines etc.You need to do more reading as this is a very simple breakdown of things and mistakes in this area can be expensive(damage engine).
WARNING: User has a low tolerance for stupidity. Post at your own risk.
redline racer510 is offline   Reply With Quote
Old 08-25-2014, 09:09 PM   #1173
smellslikerubber
i have a walboro 255 now. everything else in the fuel sytem is stock. oem injectors. i wanna make somewhere around 400hp when the car is done
Old 08-27-2014, 08:24 AM   #1174
redline racer510
550cc injectors a fpr and z32 fuel filter and dont forget to have your car to have your car professionally tuned and you will be ok.
Old 09-05-2014, 11:24 AM   #1175
lamgee
lamgee is an unknown quantity at this point
rb20det stock
I want to replace the top intake manifold with side intake manifold and to put fmic with short piping runs just like rb26 setup. Can you guys tell me who makes quality intake and fmic?
lamgee is offline   Reply With Quote
Old 09-10-2014, 08:55 PM   #1176
240Z28
240Z28's Avatar
240Z28 is an unknown quantity at this point
I have an rb25det ecu. Would that run my rb20det?
SPEED KILLS!!
Drive a Honda and live forever!!
240Z28 is offline   Reply With Quote
Old 09-10-2014, 09:57 PM   #1177
fearlessKouki
fearlessKouki is an unknown quantity at this point
No sell it and get a rb25 ecu!
fearlessKouki is offline   Reply With Quote
Old 09-11-2014, 07:38 AM   #1178
240Z28
240Z28's Avatar
So rb25 = good and rb25det = no good?
SPEED KILLS!!
Old 09-11-2014, 08:45 AM   #1179
fearlessKouki
I meant get the rb20 ecu.
Old 09-16-2014, 03:21 PM   #1180
terrance john
terrance john is an unknown quantity at this point
can someone take a picture of a rb20 tranny and show me where the speed sensor is -.- im such a noob when it comes to this.
terrance john is offline   Reply With Quote
Old 09-22-2014, 07:05 AM   #1181
JTunedMotorsports
Zilvia.net GB Vendor
Trader Rating: (65)
JTunedMotorsports will become famous soon enoughJTunedMotorsports will become famous soon enoughJTunedMotorsports will become famous soon enoughJTunedMotorsports will become famous soon enoughJTunedMotorsports will become famous soon enough
Feedback Score: 65 reviews
Send a message via AIM to JTunedMotorsports
pm me your # i will text u
JTunedMotorsports is offline   Reply With Quote
Old 09-22-2014, 02:32 PM   #1182
terrance john
pmed my man
Old 09-22-2014, 02:47 PM   #1183
terrance john
alright guys im going for 400hp ( yes ive read up) i just bought a holset hx35w turbo, question is does it bolt up to the stock manifold? also what type of 750 cc injectors should i run? and i am getting a z32 maf and a safc tuning setup. anything else i would need?
Old 09-23-2014, 05:55 AM   #1184
JTunedMotorsports
Trader Rating: (65)
What motor? Food for thought Im doing borg Warner EFR 7064 IWG, stock mani, 555cc RC, FPR, modded jun syle mani, aeromotive pump 340. z32 maf and rare PFC for the rb20. NEVER use a safc go PFC, rom tune or Haltech if you can get it to work for the rb20
Old 09-23-2014, 02:47 PM   #1185
seagrasser
seagrasser is an unknown quantity at this point
HX35 will bolt up to stock exhaust manifold, but steering column and linkage get in the way (if LHD).
S14 RB25
seagrasser is offline   Reply With Quote
Old 09-23-2014, 05:54 PM   #1186
terrance john
alright my man yes its a rb20 , this is what i bought today! hx35 ( rebuild for 300 bucks 0 miles) 850cc injectors, walbro 255. next things i need is a pfc, rom tune or haltech. any recommendations on any of these and which ones i should go with? ALSO i want to get some ls truck coils would they work with the stock ecu even though the dwell time is much higher than stock? buddy of mine wants to sell his set pre wired for 200.
Old 09-23-2014, 05:55 PM   #1187
terrance john
yeah its Lhd i have a modded down pipe for the steering colum and linkage + im getting a v band welded onto it.
Old 09-23-2014, 06:56 PM   #1188
seagrasser
OK, HX35 on a RB20 will spool fairly slow. What exhaust side is on it currently?
Check out here for another example.
#/f/showthread.php?t=543836
Also, thought I said the turbo will bolt to the manifold (both T3) there is a clearance issue with the valve cover. A spacer and longer studs will give the needed .5 to 1 inch.
S14 RB25
Old 09-23-2014, 11:48 PM   #1189
terrance john
Where can I get a t3 spacer from? And I might honestly upgrade to a rb25
Old 09-23-2014, 11:49 PM   #1190
terrance john
Rb faq
Meant to quote you but it's stock exhaust
Old 09-24-2014, 09:08 AM   #1191
JTunedMotorsports
Trader Rating: (65)
Seems like you are having some issues, I could clear up most with what we have done in the past to RB cars, just pm me.
Old 09-24-2014, 09:50 AM   #1192
seagrasser
Sorry, I wasn't clear. What size is the exhaust housing side of the HX35? Is it divided or single inlet?
There are a lot of reasons to upgrade to the RB25:
They are newer
They provide more torque
You can make some serious power
RB25 transmissions are almost bomb proof.
But, having a holset HX35 should not be your primary reason.
Here is another good thread here on Holset use. Even shows an RB25, Holset HX35, and spacer, with stock exhaust manifold
#/f/showthread.php?t=429571
S14 RB25
Old 10-19-2014, 10:59 AM   #1193
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
Alright I'm in need of a Rb guru. The machine shop I brought my Rb25 block to , punched out these plugs in the block to fully clean it. Now it's not any welsh plug, it's an iron plug either for oil or coolant. It goes straight through the block and there is 2 plugs, the front port is by the bottom large bolt on the water pump and between the oil pump, the back port is right above the rear main plate on the intake side.
If anyone knows where they can be sourced it would be very helpful!
My last option is to have a machine shop lathe me up two plugs but if they sell them it would make it easier. Thanks!
smoked240 is offline   Reply With Quote
Old 10-19-2014, 04:21 PM   #1194
seagrasser
Found an old post that might help. Otherwise wait for those more experienced than me.
#/f/showthread.php?t=259011
S14 RB25
Old 10-30-2014, 09:38 AM   #1195
redline racer510
Anyone have any experience with hx35 and r.s. Enthalpy tune? I have his tune for my stock setup plus no maf and it runs good, but anyone with major upgrades and his rom tune?
Old 01-05-2015, 01:07 AM   #1196
Beijing_Raccoon
Beijing_Raccoon is an unknown quantity at this point
Hey guys I'm going with an RB20 swap soon, and I have a couple of questions.
Is there a difference between using an R32 crossmember vs aftermarket mounts like the mckinney mounts?
I've heard with the mckinney mounts I need to make room for the starter.
Secondly, with a wiring specialties harness I'll be using the RB20DET ECU or the Stock automatic ECU my s13 came with?
Beijing_Raccoon is offline   Reply With Quote
Old 01-22-2015, 07:09 PM   #1197
fearlessKouki
RB25DET
I have strange idle surge problem that comes and goes. I have noticed that it will start to surge when i turn on the wipers. It was worse before but after cleaning the Idle control valve it has gotten better. It is totally random, also in order to stop the surging i would have to rev the motor a little until it no longer surges. Really annoying. Any guesses?
Old 01-24-2015, 07:58 PM   #1198
turbronegro
turbronegro is an unknown quantity at this point
How much are RB25's with a 5speed going for these days?
turbronegro is offline   Reply With Quote
Old 01-24-2015, 10:28 PM   #1199
seagrasser
about $2k plus or minus
S14 RB25
Old 01-25-2015, 08:49 AM   #1200
smoked240
I paid about $2500 with mount kit and 1-piece driveshaft from zero lift. That was about 6 years ago.
