heater core
I have an 89 heater core thats leaking, its the type where the tubes arent bolted on its all one big part. Where is a good place for a replacement? I would like a new one, i see some on amazon for like 40 bucks, but the dimensions arent the same, and i see some at nissan for like 200 bucks. Basically i need the core and the outlet tubes, my outlet tube is the one tahts leaking. would like to stay away from the dealer price, thanks.
look for a partout or post in the WTB section. you should find this no problem and fairly cheap.
youve been a member for 5 years and your asking this in the tech section. come on man. |
I dont want a 20 year old used heater core so it will leak again. Main question is where can i buy the heater outlet tubes, they're the most common to leak.
![]() Join Date: Jul 2007
Trader Rating: (106)
As far as I know those plastic tubes are not sold separately, they should come with ANY new heater core. Also, as far as I have seen, and I have seen a LOT, there is only 1 heater core used in S13's regardless of the year...
