Old 02-10-2008, 08:13 PM   #31
mistah_240sx
mistah_240sx is an unknown quantity at this point
very clean build !!!
mistah_240sx is offline   Reply With Quote
Old 02-10-2008, 08:45 PM   #32
Full-Lock
Full-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfection
Send a message via AIM to Full-Lock
ya man nice work
i really like your ebrake
Full-Lock is offline   Reply With Quote
Old 02-16-2008, 06:12 PM   #33
onehundredoctane
onehundredoctane's Avatar
I know it's been a while guys, hope you all enjoy the progress pics.
this is starting to take a while, it's rather hit and miss with the chemical stripper, some patches come up perfect, others might as well be cement.
cleaned up the engine mount brackets and bolted on the Cusco's, preeeeeeeeetty.
just attempting to assert any kind of flex on the Cusco engine mounts by hand doesn't get you anywhere, try that with the old stock mounts, and you get a nice flex back and forth. These things are stout.
gotta swing by HP Engines on Monday to drop off some parts, look for pics then.
Old 02-16-2008, 09:11 PM   #34
BLKS13
BLKS13 is just really niceBLKS13 is just really niceBLKS13 is just really niceBLKS13 is just really niceBLKS13 is just really niceBLKS13 is just really niceBLKS13 is just really niceBLKS13 is just really niceBLKS13 is just really niceBLKS13 is just really nice
Aircraft remover ftw! loooks good bro..keep it coming!
BLKS13 is offline   Reply With Quote
Old 02-17-2008, 01:53 PM   #35
ByeByeSti
Banned from the Marketplace
ByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant future
80 grit sand paper will strip just about anyting. 220 grit on that though to start would clean it up nice
ByeByeSti is offline   Reply With Quote
Old 02-17-2008, 02:20 PM   #36
irritatedmax
irritatedmax's Avatar
irritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enough
looking good. what are you using for a tranny mount? that is one thing i never understood about kazama/cusco mounts; they don't sell a tranny mount. that is why i went with the peak performance mount kit. i got all three mounts and i have been nothing but impressed will all the peak stuff i have experience with.
BRICKHOUSE PRODUCTS
IG @brickhouse_products
irritatedmax is offline   Reply With Quote
Old 02-17-2008, 06:47 PM   #37
onehundredoctane
I'm acutally doing the peak performance mount, just haven't got it yet.
as for sanding? that takes too long, alot of dust, and requires eye and respiratory protection, on the other hand chemical stripping, that doesn't really require so much of the eye protection (although I should), but the smell does attack your lungs, I have found a few rust places under the factory primer, further proof that it's a good idea.
Old 02-17-2008, 09:41 PM   #38
irritatedmax
get a one time use (or replaceable element one if you will be doing a lot with it) respirator. when its cold outside and i have my garage door shut, i put on my mask if i am spray painting or even brake cleaning parts and all i breathe is fresh air. it is definitely worth the $15-20. i bought mine at menards (a home depot/lowes style store here) and have worn it to prime my car and for other random dusty/smelly tasks and it still flows good.
BRICKHOUSE PRODUCTS
Old 02-17-2008, 09:48 PM   #39
driftage240
driftage240's Avatar
driftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfection
Send a message via AIM to driftage240
clean build keep up the good wok...
Misty blu is coming 4 you!
driftage240 is offline   Reply With Quote
Old 02-17-2008, 10:31 PM   #40
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
hm...chemical stripper feels like a bad idea to me
but good luck! hopefully it works out for you
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 02-18-2008, 12:12 AM   #41
Slip&Sliden 240
Slip&Sliden 240's Avatar
Slip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfection
Good choice on the hyrdo set up, here is mine. Also RHD
and my mount
Slip&Sliden 240 is offline   Reply With Quote
Old 02-18-2008, 07:06 AM   #42
irritatedmax
does your knee hit the hydro ebrake handle ever? i think mine would just based on me thinking about how i drive. i like the way parts shop max installed theirs on their s15 in the radio area. it keeps it up an out of the way. either way, nice setup to both of you.
BRICKHOUSE PRODUCTS
Old 02-18-2008, 07:33 AM   #43
onehundredoctane
since I'm the only person that will ever drive this car, I mounted the e-brake about 2 inches in front of the seat, when you pull the lever it actually travels between the seat and tranny tunnel, to answer your question, it doesn't seem like the knee thing is gonna be a problem at all.
Old 02-19-2008, 12:37 AM   #44
onehundredoctane
yay! UPS stopped by today
stopped by HP Engines and snapped pics of the SR20 progress:
tried to get pics of the hone marks, I'm not a pro photographer here people
pics from the shop:
every shop needs a dog, I however need better camera skills at times.
I swear, everytime you throw the golf ball, he brings it back, and waits to do it again.
Old 02-19-2008, 12:55 AM   #45
AznDrftr.
AznDrftr.'s Avatar
AznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond repute
Send a message via AIM to AznDrftr. Send a message via MSN to AznDrftr. Send a message via Yahoo to AznDrftr.
^LOL
nice stuff here. Love it. real rust bucket but your doing it. great sstuff
AznDrftr. is offline   Reply With Quote
Old 02-22-2008, 07:01 PM   #46
SicBastard
SicBastard's Avatar
How did you get the bracing off the inside of the trunk? Any advice would be appreciated! Looks like a great weekend project. Is it glued down, welded? Did you have to put any drill holes? Did the surface come out perfectly flat when you were done? Most of the hoods I've seen de-braced turned out a little lumpy.
BURN OUT IN YOUR FACE!
#/f/tech-talk/147301...d-gto-pan.html
Old 02-22-2008, 10:15 PM   #47
mizono
mizono is making a name for him/her selfmizono is making a name for him/her selfmizono is making a name for him/her self
Awesome build I like looking at the pics. I'm really impressed with all the time and effort you put into the car with regards to rust and rebuilding.
mizono is offline   Reply With Quote
Old 02-22-2008, 10:28 PM   #48
scooz14
scooz14 has a spectacular aura aboutscooz14 has a spectacular aura aboutscooz14 has a spectacular aura aboutscooz14 has a spectacular aura aboutscooz14 has a spectacular aura aboutscooz14 has a spectacular aura aboutscooz14 has a spectacular aura about
looks really good. have you given any though to acid dipping the shell, instead of attacking it with paint stripper. it may cost a little bit more, but what is your time worth??
scooz14 is offline   Reply With Quote
Old 02-22-2008, 11:15 PM   #49
onehundredoctane
Sicbastard- the trunk lost 5 lbs., 20 lb. before, 15ish after, not really worth it, but I wanted to see, I have 3 trunk lids, so it wasn't a waste. Cut the reinforcement out with a dye grinder, handheld cutting wheel, whatever you wanna callit. It's flemsy, you have to close it with your hand in the middle of the trunk, try and shut it with your hand on the corner and it just bounces back and echos.
scooz14- I'm not familiar with any shops or businesses in the area that would acid dip, if they did it would be costly, and atleast an hour or more away from the shop here. Besides, doing it by hand will make it hurt that much more when I hite the wall at the track. AHAHAHAA.
update time:
as we all know, dirt, oil, debris, all these road elements get trapped in the nooks and crannies of the engine bay and everything in it
before:
after being media blasted:
^make sure you tape up the injector holes
^ and anywhere you don't want clear coat to end up, not that it would matter, but always try to keep things clean!
and after a few coats of clear:
Now, leaving the intake manifold and water neck bare like this will allow them to absorb oil from my hand while I'm handling them, and installing. Along with dirt and other debris that would have the opportunity to settle into the surface. Hollis mentioned that a few coats for hi-temp clear would seal all the dirt and oils out, and look good to. Now KEEP IN MIND, I don't like bling! This is purely to keep things looking nice and clean! If this was for show, it would have been chromed.
Old 02-23-2008, 11:59 AM   #50
an_orange_s2k
an_orange_s2k's Avatar
an_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond repute
awesome build cant wait to see the end result
an_orange_s2k is offline   Reply With Quote
Old 02-24-2008, 08:31 PM   #51
onehundredoctane
PRIMER IS ON!
now, some of you might notice the body work that is still left to be done on the quarter panels. I know, I know, body filler needs to be on bare metal, but there is a new rubber body filler now that is made to be used on top of primer, it's sands easier than bondo and has a smoother finish than bondo, this way the rust is stopped and the metal has 3 shots of primer on it now.
I had thought about doing my valve cover in aluminum paint, but it turned out more like chrome, which I DO NOT LIKE!
shifter installed, note, if your doing a Fidanza short shifter, don't remove the part bolted to the tranny when installing. Your life will be alot easier
support your local machine shop!
these aren't the injectors I'll be using, but you get an idea of what the finish product will look like when it's on the engine.
Old 02-24-2008, 08:35 PM   #52
Naim
Naim's Avatar
Naim is close to perfectionNaim is close to perfectionNaim is close to perfectionNaim is close to perfectionNaim is close to perfectionNaim is close to perfectionNaim is close to perfectionNaim is close to perfectionNaim is close to perfectionNaim is close to perfectionNaim is close to perfection
Good progress.
EZ MONEY
Naim is offline   Reply With Quote
Old 02-24-2008, 08:38 PM   #53
bbejj123
bbejj123's Avatar
bbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura about
Originally Posted by kikit-sideways View Post
love that nismo front brace, going to consider getting one of those.
same... how do you like the brace? a lot better than the crappy stock ones?
bbejj123 is offline   Reply With Quote
Old 02-24-2008, 11:08 PM   #54
lflkajfj12123
those e-brakes are rad
but i thought there was a way you can mount it in the back and still have the lever in the front
Old 02-25-2008, 12:05 AM   #55
B Love
B Love is just really niceB Love is just really niceB Love is just really niceB Love is just really niceB Love is just really niceB Love is just really niceB Love is just really niceB Love is just really niceB Love is just really nice
Whoa thats alot of rust. Im glad I live in California. Cars lookin good tho
B Love is offline   Reply With Quote
Old 02-27-2008, 05:26 AM   #56
onehundredoctane
HP Engines called yesterday, my engine will be done before this weekend.
Old 02-27-2008, 08:15 AM   #57
silviavert
silviavert's Avatar
silviavert is a well-known jackass
Nice work!!!!
silviavert is offline   Reply With Quote
Old 02-27-2008, 12:39 PM   #58
motoman6968
motoman6968's Avatar
motoman6968 is making his/her stupidity well-knownmotoman6968 is making his/her stupidity well-knownmotoman6968 is making his/her stupidity well-knownmotoman6968 is making his/her stupidity well-knownmotoman6968 is making his/her stupidity well-known
you are a very brave person to take on that rusty of a car, im givin you some posi rep for that one...because you did a damn good job on it!!
... some icy white shoes and a tall t shirt i got the trunk on crack with neon lights in the back.......
motoman6968 is offline   Reply With Quote
Old 02-27-2008, 01:07 PM   #59
heyitzalan
heyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant future
damn, this is hell of a good built.
heyitzalan is offline   Reply With Quote
Old 02-27-2008, 03:31 PM   #60
sr20boostn20
sr20boostn20's Avatar
sr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of light
Send a message via AIM to sr20boostn20
this build is fresh.
you are the man.
alotta time went in to this.
i love to see people that care.
sr20boostn20 is offline   Reply With Quote
