z32 vh45de shell
car is located at san marcos texas.
512 665 8575 vin: shown in picture shell! no engine. comes with s14 se wheels. stock car modded crossmember for vh, vh wiring plug and play, adapter plate from elwesso. 5speed trans drive shaft, q45 fuel pump.. pretty much you just need to source and engine and radiator and get her going. 2k obo!!! without adapter plate or trans: 1500!!!! History: swapped a vh45de in it. modded the cross member to accommodate the oil pan and motor mounts. welded some brackets to use 240sx radiator mounted slanted just like the z31, it can easily be reversed back to stock if needed. when it was at its prime. not really complete but the best it was. blew up the engine. bought another engine but then ran into an s13 that had suspension and shit. thinking over it, the z is expensive to mod for me right now. will get more pics. inside is clean and compete. driver t top is not too pretty but it seals. the body has ding here and there and paint is faded. |
| datoctopusjuice, v8bro, vh45de |
