Holset SR
Finally, after a year an a half. At 10lbs until I can figure out why its breaking up at around 5500. Been checking off alot of the things that it could be. Pretty sure I missed a boost leak. It happens about 50% of times I've tried at wot. So more boost will wait. Got an electric cut out coming today bc the 3in to the bumper is loud. And a decent looking muffler to get welded on tomorrow.
YouTube - SR exhaust 3inch YouTube - Sr20det Big turbo 240 Tried putting the youtube video in the thread, i suck. Last edited by mistamacadamian; 03-09-2011 at 02:34 AM.. Reason: video not working |
No, spun a bearing in the old motor a week after i first got it running. took some time to save up and bought a long block and swapped the setup. when you let your friends work on your car they tend to miss shit. i've run into stupid problems bc i didn't double check over things. I'm probably going to go ahead and do a mid mount set up on it soon. on 10lbs with 264's it doesn't get full boost till 4000.
