Old 04-24-2016, 02:25 PM   #1
steveff
steveff is an unknown quantity at this point
rb20 s13 no headlights or brake lights [help]
So I completed the swap in my s13 and went to drive it yesterday and the headlights and brake lights do not work.
What does work:
FRONT blinkers / flashers / fog lights
REAR running lights / blinkers / flashers / reverse lights.
NO headlights, high beams, or brake lights.
Switches are good because the relays click on. But the fuses aren't getting power. Hooked up a multimeter to the fuses and got nothing.
Every fuse/relay in the entire car is good. Checked em all.
So I'm thinking I missed a connector / ground or some sort of BS I'm overlooking. Cant find any plugs or connectors that mean anything to this issue that are unhooked. Don't see any loose or missing grounds. Went over everything with a fine tooth comb. Just seems weird because they're two separate things as far as I know, so what could I be missing that effects both of them??
Any ideas guys?
steveff is offline   Reply With Quote
Old 04-24-2016, 02:33 PM   #2
hobbs
Trader Rating: (43)
hobbs is on a distinguished road
Feedback Score: 43 reviews
Grab the FSM and start to trace back through the circuits and find out where you are and were you arnt getting power. Every single harness is blow apart in the FSM along with connectors.
My guess would be the column switch.
hobbs is offline   Reply With Quote
Old 04-24-2016, 02:34 PM   #3
steveff
R32 gtst FSM or an s13 FSM.
Sent from my SM-G925T using Tapatalk
Old 04-24-2016, 02:37 PM   #4
hobbs
Trader Rating: (43)
S13 FSM, only thing that interfaces with your RB20 would be the lower transmission harness for the reverse lights.
Old 04-24-2016, 03:30 PM   #5
Tyler_240
Tyler_240 is an unknown quantity at this point
Are you sure you remembered to plug in your dash harness? the white plug on the passenger side above the ECU way up in the dash?
/my 2cents
Tyler_240 is offline   Reply With Quote
Old 04-24-2016, 03:30 PM   #6
steveff
Yeah. Dash lights and interior lights all work.
Old 04-24-2016, 05:12 PM   #7
cotbu
cotbu's Avatar
The red plug on the battery is power for the headlights. So if you relocated the battery or just forgot those plugs. That might be your issue. Post a picture in a minute.
Old 04-24-2016, 05:13 PM   #8
steveff
I did relocate the battery.... I don't remember seeing any red plug
Old 04-24-2016, 05:17 PM   #9
cotbu
cotbu's Avatar
Did you get that picture?
Old 04-24-2016, 05:18 PM   #10
steveff
Yeah I got it.... I have no idea where that plug went.
Old 04-24-2016, 05:19 PM   #11
cotbu
cotbu's Avatar
Do you have the wires that plug into it, if you do add 12v to it and you lights should work.
If you're not sure, if they are the correct wires, remove the headlight fuses and check continuity from the wires to the fuse.
Old 04-24-2016, 07:16 PM   #12
steveff
So black is alternator and green are headlights. Headlights are figured out now, just need that red plug or a terminal block.
What about brake lights now?
Old 04-25-2016, 07:31 AM   #13
steveff
Up
Old 04-29-2016, 10:20 AM   #14
steveff
Got it figured out. Headlights were that little red plug that I just hardwired. And the brake lights were a loose power wire going into the interior fuse box.
Weird how both happened at the same time though. Thought for sure it would be related.
Thanks again to whoever suggested that little plug, totally slipped my mind.
