Old 07-07-2009, 04:54 PM   #1
MrFixIt
MrFixIt's Avatar
MrFixIt will become famous soon enoughMrFixIt will become famous soon enoughMrFixIt will become famous soon enough
Axle leaking grease?
Yep. Smashed my car (S13) into a wall on my driver's side. Ended up demolishing my tension rod, FLCA, RLCA, toe rod, and bending my subframe. But that's another story.
When I went underneath to inspect/remove everything I also swapped out my welded dif for my open (no more dorifto for me ). When I unbolted the driver's side axle from the diff it started leaking this orange-y cream colored goo (Axle grease?) from where the axle attatches to the dif. To be honest I didn't inspect the rubber boot thingy on the axle very carefully, but I didn't see anything that immediately jumped out at me. I let the fluid drain out untill it stopped (leaked maybe, 2-3 table spoons worth of goop) then bolted it back up.
I've been driving for maybe, 400-500 miles since then without any noticable noises, grinding or clunking or anything.
I was wondering if anyone could help me figure out a) wtf leaked out of my axle haha, b) did I damage anything, c) how bad is it to run around on an axle that, potentially, has lost a majority of it's grease, d) what can I do to fix it, as in, can i get a new boot and repack the joint or do i need a whole new axle.
I found this: #/f/tech-talk/96731-...le-grease.html and now I'm worried haha. I was wondering if anyone could provide some more situation-specific insight. Any help is greatly appreciated. Thanks.
MrFixIt is offline   Reply With Quote
Old 07-14-2009, 01:19 PM   #2
MrFixIt
MrFixIt's Avatar
Not trying to be a jackass bumping my own thread, but anyone have any advice? input? chicken parm recipes?
Old 07-14-2009, 01:41 PM   #3
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
gat a new used axle they go for nothing
Old 07-14-2009, 03:31 PM   #4
projectRDM
projectRDM's Avatar
The CV joint is filled with 'dope', a thick, heavy grease. An impact can pop the rear cover on the axle loose or even off, allowing the grease to leak out. I'd pull it again and see if there's continued leakage, replace it if there is.
FORMERLY R240NA
