S13 Passenger flip up light won't go down.
Hello zilvia,
Before i start, yes, i searched. my passenger side headlight won't go down. i bought the car with this issue. I checked all the 4 relays and checked the 2 fuses. I even put in a brand new headlight switch and I have the same issue. Is it possible for the headlight motor to be bad even though it puts the headlamp up but now down? I am running out of ideas |
![]() Join Date: Sep 2005
Take off the cap, spin the knob, keep going until it auto retracts and comes back up. then turn your lights off normally.
If you just bought this car? check the button on the cluster for modification. most likely the brown wire, if broken reconnect it. Other than that get an FSM and multimeter, troubleshoot. Sent from my SM-N910T using Tapatalk
