![]() Join Date: Nov 2011
Going to helicoil my block but worried about shavings
I installed ss turbo lines however they were leaking so I pulled everything off and used copper washers this time. When putting everything back, I noticed the oil feed in the block was somehow stripped now. After doing some searching it seems helicoil is my best bet (since im sure ill be upgrading turbo at some point). The only thing I worry about is getting shavings inside the block. What can I do to avoid this as much as possible and if its unavoidable, what can I do to get them out? Does the hole simply dump everything in the oil pan where my magnetic drain bolt will catch it along with the oil filter?
![]() Join Date: Nov 2007
Trader Rating: (36)
![]() ![]() ![]() Feedback Score: 36 reviews
The block is aluminum, a magnetic oil drain plug won't help you. lol Maybe tap with a thick grease? Or go slowly and use a vacuum cleaner with a tiny fitting to suck the shavings out as you go.
![]() Join Date: Jul 2012
You dont even have to helicoil it man. Same thing happened to me and all i did was retap the threads and replaced the banjo bolt with an AN fitting. I used a lot of grease on the tap to catch the shavings and only did like two turns then backed the tap out, cleaned the grease off and put more grease on. Repeated that process.
And if you want to be more safe, just unplug the cas and crank the engine over a few times while the line isnt connected. Yeah oil will spew out, but id think it would push any left over shavings out.
#5 | |||
duh, im dumb.Quote:
I've read retapping it works however next time I remove it I'll just run into the same issue. Maybe I'll do that for now and worry about the rest later haha. Rerunning the same banjo bolt would be easier for me, but I guess I could alter my existing line to work with an AN fitting. Do you know what size AN fitting you used? |
![]() Join Date: Jan 2011
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
Follow this thread
http://forums.nicoclub.com/diy-strip...t-t443899.html Javi sounds like it worked for him. I actually have the same exact problem and I will be doing the same thing. Potato what do you mean you might have the same problem again? If you change it to An fittings then you would just disconnect it from the other side. Why would you ever need to touch the block side of the oil feed ever again? I would just advise you to do as I am doing and double check with the vendors who sell the ss turbo lines (what you have to use when you use an fittings) and ask what size it is. Some turbo lines are -3an and some are -4an. this will make a difference in what size adapter you buy. I will fix my shit after finals are over |
#8 | |
I thought you needed a hole that bottoms out to helicoil it?
Attempting to rethread it the same size would be risky and fultile IMO. If it were me I would tap it the next size up in AN too. No new info here, just a third-forth concurring opinion |
![]() Join Date: Jul 2005
I did this years ago on a redtop.
Drill a nice straight hole. Helicoil. Let some oil push out whatevers inside. vacuum cleaner would be nice but I didnt. |
I was thinking about it too but its just for peace of mind to go into An fittings
Most turbo SS lines come with the proper restrictor ( banjo bolt act as a restrictor) |
