| South Western States Arizona, California, Hawaii, and Nevada. |
Hey what's up Zilvia was wondering if anyone knows where I could go to get my 5 lug rotors drilled out to 4 lug. I stay in 909 area code. I know someone but in Santa Ana I really don't want to drive out there unless I can't find anyone near me. Thanks ahead of time.
#2 | |
![]() Join Date: Dec 2011
![]() Join Date: Jun 2008
to the OP, ive done this multiple times. its very simple. just lay the 4 lug and 5 lug rotors face to face, tack a nut and bolt that are the same size as your lug stud and bolt the 2 rotors together through one of the bolt holes and line up the hub holes.
Then, all you have to do is get a drill bit thats the same size as your lug stud and drill out the 3 remaining holes. BAM! 4 lug z32 rotors.
#9 | |
![]() Join Date: May 2009
Make sure you bevel the lug holes you drilled just a bit like the holes that are already in it. Will help cut down on cracking around the hole you drilled.
Also make sure you lube the drill bit as your drilling.
| 4 lug, 5 lug, brakes, rotors |
