ka24de fuel system not working after swap
Whats up zilvia... So after about 3 weeks of searching online I'm finaly just gonna ask. I just receantly swapped another ka into my s13 coupe I have everything connected but my fuel pumpwont prime and my injectors won't go on or spray I checked the fuses and relays still nothing I can't find what the problem could be.
![]() Join Date: May 2009
![]() Feedback Score: 20 reviews
id get a volt tester and start checking around, something somewhere isint connecting.
did you connect the dash plug on the harness? did you use the same ecu and harness? is it a s14 ka? need more info! |
![]() Join Date: Mar 2004
If you are not getting power to the fuel pump, then you should check that entire circuit...
Once the fuel pump is working again, then move to the fuel injector and fuel pressure regulator to see if there is fuel pressure... ![]() If you don't know how to read a circuit diagram, learn it!... You will be able to solve a lot of problems if you take the time to learn how to read this...
http://respectvolkracing.blogspot.com/ |
![]() Join Date: Nov 2009
Trader Rating: (35)
![]() Feedback Score: 35 reviews
post info on engine and mods...
start with the basics like checking if there is power, ground, plugs are plugged in completely etc. these type of issue usually result on forgetting a plug or a ground. It happens to everyone... including me alot. lol |
So i ended up seeing the brown connector wasn't pouted in all the way be the ecu and now I have fuel so thanks for the help but now i have another problem now it won't start it cranks but all its doing is back durring as it cranks -___- any help with that ?
