oil change then..knocking.. help?
Alright so the situation goes I do a fresh oil change 20 50 cause the cluster says 202000 miles I finish the oil change I let the car idle for about 5 mins and then a knocking sound starts sounds like its coming from the head but its extremely loud by the driver side under the car I put Lucas and it went away but as it was taking in the Lucas it was going and coming back like it got louder until it stopped its a ka24e I will get a video if the noise come back any suggestions to what it is ? Too thick of oil is the only thing I can think of
![]() Join Date: Oct 2009
![]() ![]() Feedback Score: 11 reviews
yea 20-50 is super thick... 10-30 is fine for an older motor, maybe add that lucas oil stabilizer.
That thick of an oil might not getting sucked up by the oil pump... You might want to open up up the oil pan now though as you will see metal shavings from the knocking you heard.
@dangerdamian |
That's what I was thinking the reason why I put such thick oil cause the car is old and I live in Miami and its summer and idk what oil it had before cause I just bought the car in December
drain it and put a 10-30 with stabilizer. Should be fine no? idk i live in cali...
thats what i used all year. im guessing 20-50 works in florida???
@dangerdamian |
![]() Join Date: Apr 2009
u should be fine with 20-50 in your motor
its not like 20-50 is maple syrup maybe in cold cold weather but we live in florida i would run the heavier oil over 10-30 anyday it gets way to thin |
#17 |
Alright so half of you are telling me to stay with 20 50 and the other are telling me to change I'm going to drain and see what happens if the noise starts again I will get a video so there's more detail
#23 |
![]() Join Date: Jul 2009
I always ran 10 30 in my 240sx single cam, had the car since 2001 had 189,xxx miles when I bought it, now has 235,xxx miles and I'm still running 10 30, have no problems in the 100 degree weather
#27 |
![]() Join Date: Mar 2011
yea you definitely starved the head of oil thats for sure.
It will be a crap shoot if the noise goes away just depends on the extent of damage.
1991 Nissan B13 Sentra sr20det 300whp/1991 Nissan S13 240sx sr20det ~260whp |
