a few technical problems...maybe easy fixes for u experienced cats
hey my idle is around 1900rpms
how the hell do i lower it?? thats all i can think of from my tiresome day ill add more if i think of anything else thanks in advance. -Jerzy |
well i did a lil more research and found there is a visible screw in between the 2nd and 3rd runner of the intake manifold and i can adjust through that thanks for the help
![]() Join Date: Dec 2002
If that doesn't help, replace the IAA unit. High idle is more common of that to be bad then the IACV to be out of adjustment.
hey guys im having problems with my tranny i cant get it to go into first nor secondbut when we took it out we didnt find ne problems with the gears then when we put it back in we cant get 1st or 2nd ne tips??
![]() Join Date: Sep 2005
if it doesn't go in at ALL you more than likely have things misaligned from when you dropped the tranny, took it apart, then reinstalled it. Slave / Master is a good place to start though since the tranny is still installed
Been awhile... |
