Old 06-14-2012, 09:46 AM   #1
BlacknboostedS13
BlacknboostedS13's Avatar
BlacknboostedS13 is an unknown quantity at this point
RB25DET Series 2 A/C Compressor or not?
I purchased a series 2 RB25 a few months ago and have been slowly freshening it up before the drop in. I've decided I wanted to use A/C because it gets hot as shit in FL and this will be my DD. The problem is, The motorset didn't come with the A/C line ends, so I went out and bought some from another s2... They don't fit... The I.D. of the low and high pressure sides are 2-3 mm bigger on the compressor than the O.D. of the lines... I searched the forums and googled the part numbers and only came up with 1 legible australian thread on it but no answers and a few others in Japanese? I'm hoping either you guys can help and know what lines will fit this or can read Japanese to tell me wtf they were sayin...
BTW: I already contacted Nissan with the part number, they had no idea as it was showing that it wasn't from the US.
BlacknboostedS13 is offline   Reply With Quote
Old 06-14-2012, 10:08 AM   #2
Sileighty_85
Sileighty_85's Avatar
that is a series 2 Comp, but those lines might not be
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 06-14-2012, 10:16 AM   #3
BlacknboostedS13
I bought the lines from JDMTech in Orlando and they said they got them off of an s2, I guess they could be lying. I guess my hunt continues.
Old 06-14-2012, 11:23 AM   #4
Sileighty_85
Most import companies dont know exactly what the engine came out of.
The Rb25 came is quiet a few other chassis other than the R33 and they look exactly the same minus some small parts
後輪駆動車1番
1986 SR86 - 200ish
Old 06-14-2012, 02:18 PM   #5
KendallH
KendallH is an unknown quantity at this point
I have an s2 compressor with line ends bolted on, if you can't get it to work.
KendallH is offline   Reply With Quote
Old 06-14-2012, 07:27 PM   #6
feito
feito's Avatar
series 2 in s14, custom lines:
high pressure line's welded 1 1/2" after the hose by the service port, the rest came with the engine which is from an r33, at least they told me...
low pressure one, well you can see the welds where its all shiny, hope this helps
Old 12-26-2012, 12:23 PM   #7
MR_GUTTI
MR_GUTTI's Avatar
MR_GUTTI is an unknown quantity at this point
So u used rb25 fitting on s14 lines?
MR_GUTTI is offline   Reply With Quote
Old 08-10-2016, 11:36 AM   #8
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
bump, as I'm encountering this issue now!!
supersayianjim is offline   Reply With Quote
jdm, rb20det, rb25dett, s13, skyline
