Old 10-03-2011, 07:27 AM   #1
spray2020
spray2020's Avatar
spray2020 is an unknown quantity at this point
s13 silvia stock suspension rubbing on tire? (pic)
So I just bought this 1990 rhd silvia, and I noticed that the passenger side suspension is literally sitting right above the tire- if not on the tire.
The tires on these wheels are new, and they are starting to get a worn area because of the rubbing.
Is this a sign that the springs are bad? I dont think a bad shock would cause this?
On the other side there is no rubbing, and the clearance is about 2 centimeters from tire to suspension.
photo:
[IMG][/IMG]
spray2020 is offline   Reply With Quote
Old 10-03-2011, 10:36 AM   #2
Sileighty_85
Sileighty_85's Avatar
spings has nothing to do with that, Thats what happens when you put on aftermarket rims with giant bubble tires on stock suspension.
Coil overs or lower Profile tires will fix that, (Or some 25mil Spacers)
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 10-03-2011, 02:09 PM   #3
spray2020
spray2020's Avatar
are they really that big? I mean, I didn't put them on the car- I bought it like that.
They are nissan rims with the center caps off, and 205/65/215's
fair enough, I will try to find some spacers for the time being.
Thanks
Old 10-03-2011, 07:36 PM   #4
Sileighty_85
Spacer May or May not fix it cant really tell from pic but yeah some 65 side walls are huge. a 50 series would be best
後輪駆動車1番
1986 SR86 - 200ish
Old 10-04-2011, 02:19 PM   #5
spray2020
spray2020's Avatar
ok thanks guys for your imput-
you are right indeed- they are nissan pulsar wheels with bigger tires- as the mechanic told me who last serviced the car with the previous owner. grrrrr
Old 10-04-2011, 10:49 PM   #6
andrew600
ill tongue punch her fart box
andrew600's Avatar
After seeing this thread and the other one you made it seems like you got fucked with no lube. You ever buy a used car before?
andrew600 is offline   Reply With Quote
Old 10-11-2011, 09:21 PM   #7
CASilForty
CASilForty's Avatar
CASilForty is an unknown quantity at this point
s13
if wear is on the inside corner of the tire it may be chassis rub not coilover interference i had same problem theres a ridge that sticks out ftom the back of the wheel well by the hard brake lines. if it rubs yer tire pound it back flat with a hammer
CASilForty is offline   Reply With Quote
