Anyone w/ experience on fixing the rear window trim?
Just looking for some opinions on how to go abouts fixing this shit..lol
Its from the back window of an S14 |
#3 | ||
![]() Join Date: Feb 2010
I'd worry about your rust problem first
yeah, you're better off getting a completely brand new one, but delado is right. You should definitely get the rust issue out of the way first. The weather stripping from what i've seen go for is about $80-100. GL
weatherstripping is the least of your problems
that glass needs to come out to assess the extent of the damage fix whatever caused water to accumulate there then bodywork to fix rust and paint ouch |
![]() Join Date: Apr 2006
Trader Rating: (55)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 55 reviews
window places can put a new universal trim on for you and for cheaper then a oem trim and it looks better. if u want a easy cheap fix to glue down the piece that is lifter you can use black window seal from permatex or 3m
