parts galore! lots of stuff you might need
location: viriginia contact: PM or text 540-903-4022 tired of my shed and room being clustered up with stuff im not using so heres what i got, if your going to flake please dont waste my time because im really sick of people flaking out lately. s13 ka24de intake cam-$20 aftermarket honda half radiator-$75 sr20 t25, blown and needs a rebuild-$45 s14 front and rear calipers, spindles, 4 lug hubs- let me know what you need and well talk price from there sr20 power steering pump with red light weight pully and tensioner and bracket-$50 ka24de flywheel-$35 s13 5 speed brake pedal-$30 sr20 t25 wastegate actuator-$20 n60 mafs-$40 j30 front calipers, brackets-$60 x3 j30/z32 ignitors-$25 each q45 ignitor-$25 ka24e distributor, cap, and rotor-$30 ka24de alt-$30 ka24de coil-$25 x2 oem sr20det O2 houseing (good for a budget t25 setup)-$15 each oem s13 suspension-$25 pick up s13 ka24de oem header-$5 pick up s13 hatch oem taillights-$35 s13 SR blue valve cover-$60 ca18det stripped valve covers-$45 s13 KA24de valve cover stripped-$35 r32 skyline crossmember-$70s14 oem tension rods-$30 ca18det oem turbo manifold-$40 s14 ka24de distributor-$45 S13 coupe sunroof glass with latch-$50 r32 powersteering resevior-$25s13 SR fuel rail (no injectors)-$20 s13 ka injectors (270 side feed)-$30 s14 bumper parking lights (new)-$30 450cc top feed injectors (from a plymouth lazer)-$100 sr20 t25 oem wastegate-$20 ca18det t25 wastegate-$20 s13 SR20 water neck-$40 s14 steeringwheel airbag-$50s13 sr oem exedy pressure plate-$30 s13 front OEM calipers with OEM lines-$30 HKS bov flange only, never used-$10 thats about all i can think of right now, i got some other random parts too just ask me and ill take a look at what i got. sorry for the shitty cell pics ![]() ![]() ![]()
I'm so JDM i sleep on the right side of the bed. |
