![]() Join Date: Aug 2010
damn wtf!
Just when I think I'm done
Just installed some 240/248 cams on 14 today. Did everything proper or so I think. All my markings lined up and everything. So when I go and turn the engine manually by hand I feel some binding on my breaker bar. I took out the spark plugs just to make sure it wasn't some good ol compression. So my valves are touching the piston. What should I go back on and double check? Thank you for your input! -I already double checked the torque on the cam caps |
![]() Join Date: Dec 2004
Trader Rating: (58)
If you're valves hit the piston you need to take the cams back out and reinstall them.
WIth that said, keep your fingers crossed that you didn't bend a valve too....
