Delicious Part out, Lots of aftermarket!
Finally decided to part out my S13.
Lots of after market parts. Everything i have for sale is 3K miles or less of use. Only street driven, never taken to a track or beaten. If you want something thats not on the for sale list, make me an offer. I have a lot of stock parts, subframes, DOHC steering lines, blah blah blah. I prefer pick up for the big things, body kit, motor, etc... unless you want to pay shipping. Ill take cash, check, paypal. Email me at [email protected] or PM me. If i take a while to respond, please be patient, ill be parting out all day! Sr20 stuff- Alternator - 50 Starter - 50 Lower Engine Harness 40 Upper engine harness with 300zx Maf Plug - 100 Stock ECU - 80 CAS - 80 Coil Packs - 50 Intake manifold - 50 Throttle body - 60 Stock 370cc injectors - 20 each fuel rail, not bent - 30 Heater hose conversion lines - 20 Intake Apexi SR20Det z32 racing suction kit $180 Z32 maf 100 greddy type rs BOV 140 Exhaust Fat type O2 sensor 80 nismo exhaust bushing kit 30 Cooling FAL dual 12inch fans 180 Red samco Lower radiator hose silicone 30 Stock KA Radiator 40 Drivetrain Exedy stage 1 clutch 250 XACT flywheel 12 pounds 250 Nismo engine mounts 100 Fuel/ ignition Apexi AFC NEO 300 Engine accessories HKS manual boost controller 70 Suspension/ brakes circuit sports rear strut bar 80 circuit sports front strut bar 80 suspension technique sway bars 180 MR rear traction rods 70 MR rear toe rods 70 oem brake master cylinder 100 JDM Brake booster 40 Exterior Origin lab stylish kit 700 Origin lab type 1 hood 400 Aero catch hood pins, Flat black 70 Origin type x position lights, clear 70 Electronics Westco Battery 80 pioneer head unit 100 Stock Stuff Uncracked dash 80 Rustless, Wingless hatch 40 Tail lights 30 Rear crash guard 20 Andy's AutoSports bottom mount seat rail - Driver and Passenger 80 Clutch Master cylinder. 20 rear subframe, spindles with energy suspension bushings in the spindles. 50 left Stock front spindle 10 JDM gas pedal. Its straight up and down rather than slanted. 5 Stock gas tank 20 Entire DOHC steering setup- pump, reservoir, plumbing stock KA radiator in good condition 40 and the pics! ![]() Last edited by IStop4NoMan; 01-21-2010 at 02:30 PM.. |
![]() Join Date: Jan 2008
Trader Rating: (26)
geez that's annoying to read.... here.
Heres the list Intake Apexi SR20Det z32 racing suction kit $180 Z32 maf 100 Greddy M-spec intercooler kit 300 Hotpipe with greddy port 100 greddy type rs BOV 140 ExhaustMegan 3" flexible downpipe 80 Greddy O2 extension 150 Fat type O2 sensor 80 HKS Hi power catback 400 catco hi flow cat 110 nismo exhaust bushing kit 30 Megan racing t25 manifold 100 Cooling SR20 koyo radiator 100 sr20 fan shroud 30 FAL dual 12inch fans 180 Red samco radiator hose silicone 40 Circuit sports aluminum coolant reserve tank 75 DrivetrainExedy stage 1 clutch 250 XACT flywheel 12 pounds 250 1 piece steel driveshaft DSS 250 Megan racing lightweight pulley set 70 Megan racing short shifter 40 Circuit sports stainless steel clutch line 20 AGP auto to manual clutch line 20 nismo engine/ tranny mount 170 CS aluminum subframe mounts 40 nismo extended wheel studs 10, 30 energy suspension steering bushings 5 Fuel/ ignition Walboro 255gph fuel pump 80 Apexi AFC NEO 300 engine accessories circuit sports mini oil catch tank 10 HKS manual boost controller 70 circuit sports turbo lines 70 suspension/ brakes circuit sports rear strut bar 80 circuit sports front strut bar 80 nismo power brace 125 suspension technique sway bars 180 megan racing street coilovers 600 battle version tension rods 150 MR rear upper control arms 110 MR rear traction rods 70 MR rear toe rods 70 oem nissan front lower control arms 70 oem outer tie rods 20 oem brake master cylinder 100 JDM Brake booster 40 Interior VIS carbon Racing bucket 300 Momo leather steering wheel 150 Momo steering wheel hub 50 circuit sports quick release 50 Bride seat rail 120 four point silver sparco seatbelt + Pads 75 boost gauge 20 water temp gauge 20 A pillar gauge pod 20 Exterior Origin lab stylish kit 700 origin lab type 1 hood 400 5 zigen FNO1RC 17x8 +35mm + dunlop 235/40 700 Electronics Westco Battery 80 pioneer head unit 100
ಠ_ಠ |
Im in Chino
if you guys want to get a hold of me, my cell is 909 576-3407. hatch is for sale, no rust but needs paint. $50 bucks Have a power steering pump, $40 bucks mini catch can could use some detailing, but works just fine Let me find out how much the shipping is on the FN's and suspension technique bars, Ill get back to you on that. I dont want to part out the sudeskirts, but i do have a set of knockoffs that are identical. Ill do those for $50 bucks picked up! |
#21 |
Radiator, coolant reserve, nismo power brace, driveshaft, coils, clutch line, intercooler kit, MR short shifter, MR pulley, and subframe solid bushings have been sold! as of 12/29/09 at 5PM
#25 |
![]() Join Date: Dec 2003
maybe he meant $150 each?
you willing to ship the power brace? if so I will find a couple more things to buy to make it a lil more worth it.
S.P.P.S. Member #00**CoUpe LOve** Member #00 |
#27 |
Hey Patrick it's JP, i got the DP and Clutch line. I will be out of town coming back next week. do you think you can hold the short shifter for me ? let me know.
Thanks |
