Ka24e-t
So I decided to stay ka24e instead of doing a sr or rb swap. Im new to all of this and just need some guidance on what all i need. I started a list, just let me know what else i need thank you.
ka24e turbo kit from cxracing.com cxracing catback exhaust systm radiator and shroud walbro fuel pump 550cc injectors z32 maf tune ecu and thats about it for now thank you |
![]() Join Date: Mar 2007
![]() ![]() ![]() Feedback Score: 12 reviews
You don't need a boost gauge or a wideband. The stock ecu is good till 25 psi as well as that turbo. Duct tape your maf to your turbo and run no air filter for maximum Jdm HP
![]() Join Date: Jul 2008
Trader Rating: (32)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 32 reviews
honestly, its better to piece your own kit together with qhality parts. that turbo and manifold from cx racing sucks. besides that cx racing intercooler and piping is good. get this log manifold instead cause its stronger.
JGYCustoms.com - 240sx KA24DE(T) Exhaust Manifold and Turbine Outlets as for a good, cheap, turbo go with an older 300zx T3 turbo. theyre good for about 280-300 hp i believe. |
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
^The problem with those is that they're a 7 bolt turbine, rather than a conventional 5 bolt. This means shenanigans trying to get a downpipe built.
Visit the sohc-t section of ka-t.org and read up a lot. Having done both, I wish I would have just bought an SR to start with. Easier, more reliable, actually revs, and better mpg to boot. |
Trader Rating: (24)
Don't get upset, I didn't call you stupid or anything, so calm yourself.
So you want a bigger turbo? I've owned a couple as well, and was all set to buy the 7 bolt turbine flange from blaastperformance.com (not sure if they're still around) but ditched it in favor of a traditional t3/t4. My 'read up a lot' comment was directed at the OP. No one should be posting for info about what to do for ka-t -- rather, they should be researching the hell out of everything and making up their own mind before undertaking the project. |
#9 | |
![]() Join Date: Aug 2008
If you have NEVER owned a forced induced vehicle, i highly suggest you boost the ka instead of going out an buying a SR since parts are readily available and you arent stuck without a car for awhile. CX Racing is shit as far as for turbo kits...it would be better for you to piece your own setup together as well as cheaper. Take a trip to KA-T.org - The Home of 1000+ whp/7 sec Turbo KA's and talk to Jordan. Tell him that Demonspeed sent you
IMO, since you are a single cam, the part that will cost the most is the mani.
#10 | |
Also i would go with:
Jordan manifold Stock t25 turbo fmic (although you could get away with a sidemount) z32 MAF RX-7 injectors Oil lines But thats just me lol...
![]() Join Date: Apr 2010
rb injectors will work as well, jgs mani's are bad but they arent the best. Dont waste your money on cxracing garbage. Dont spend time on ebay building your setup either. Do some research on ka-t.org like everyone else is saying. I guarantee youll pick up some good parts on there. Your probably going to be making your own intercooler piping so be prepared for that. And make sure you get it tuned (it will not handle 25 psi stock) Since its probably your fist turbo car and i doubt your going to build the motor, id suggest running 7-9psi max and make sure you have a respectable company tune it for you.
