![]() Join Date: Aug 2006
Trader Rating: (105)
![]() ![]() ![]() ![]() ![]() Feedback Score: 105 reviews
Hi, I am listing some of my sr20det parts that I no longer need. If you see anything you are interested in please post or send me a PM. Prices do not include shipping, please leave zip code for quote. I accept paypal and ship fast.
OEM head bolts w/ washers-$20 ![]() S13 cams-$70 for pair S13 cam gears-$30 for pair ![]() Oil feed tubes-$30 for pair ![]() Rocker arms-$80 for set of 8 ![]() S13 blacktop valve cover w/ T and PCV valve-SOLD Valve cover T-$5 ![]() OEM oil cap-$10 ![]() OEM timing cover / oil pump-$80 ![]() Timing chain tensioner-$30 ![]() Crank / oil pump collar-$10 Crank pulley bolt w/ washer-$10 Lower timing chain gear-$10 ![]() S13 pulleys P/S pulley-SOLD Water pump pulley-$10 Alt. pulley-$10 ![]() Thermostat housing-$20 ![]() Temp sensor harness-$20 Water outlet-$30 ![]() Water inlet-$20 ![]() S13 intake manifold-$40 ![]() Intake manifold brackets-$20 for all 3 ![]() PCV valve to intake lines-$20 ![]() Coolant lines under intake manifold-$30 ![]() S13 throttle body w/ auto TPS-$60 ![]() Auto TPS-$30 ![]() S13 fuel rail-$30 ![]() FPR-$15 ![]() Mishimoto radiator cap-$15 ![]() Q45 MAF-$50 ![]() OEM exhaust manifold-$40 Blacktop rods-$80 for all 4 ![]() Crank girdle-$40 ![]() Main bolts w/ washers-$20 ![]() Oil pickup / strainer-$25 ![]() Oil sending unit-$15 ![]() Oil dip stick w/ housing-$25 ![]() Dip stick housing-$10 ![]() Knock sensor harness-$20 ![]() Rear seal housing w/ seal (one tab broke)-$20 ![]() SR engine flex plate-$40 ![]() SR OEM flywheel (resurfaced then used for 5k miles)-$50 ![]() SR flywheel bolts-$20 for all 8 ![]() HKS T28/GT28 internal wastegate-SOLD Throwout bearing sleeve-$10 S13 complete manual driveshaft non abs-$120 ![]() SR / KA engine brackets-$40 for pair ![]() Skyline engine mounts (240sx upgrade, solid rubber)-$120 ![]() J4 type x blacktop engine harness (complete and uncut)-$190 J4 type x Intec tuned ecu with switchable tune (up boost, modified fuel and timing, no fuel cut, all bolt ons)-$200 Ignitor chip-SOLD Coil pack harness-$30 ![]() T28/GT28 bottom mount turbo line kit (steel braided water lines, hard oil line, AN fittings, banjo bolts, and washers)-$60 T25 water inlet line-$10 T25 oil feed line-$10 Water line banjo bolts-$5 each DIF Goodridge T2 bottom mount return line-$40
PM me for s13 or s14 parts! Last edited by s13 drifta; 11-18-2013 at 08:45 AM.. |
T2 3 bolt compressor outlet-SOLD
T2 HKS 2 bolt compressor inlet-$30 ![]() Steel cold pipe (looks like Greddy)-$50 ![]() Vortech FMU 12:1-$80 ![]() Billet BOV w/ pipe-$40 28x6.5x2.5 FMIC (little tweaked, still works good)-$30 ![]() Autometer fuel pressure gauge w/ steel braided line-$30 ![]() Thanks for looking!
PM me for s13 or s14 parts! Last edited by s13 drifta; 07-19-2013 at 10:46 AM.. |
#4 | |
![]() Join Date: Feb 2003
Trader Rating: (289)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 289 reviews
nice for sale thread, looks very professional
![]() Quote:
i need the Crank / oil pump collar-$10 i wonder if it will fit my s15 sr crank? If you konw please linform me so i can buy this.
had my oil pump die on me recently and damaged this part...
![]() Drake: 95 Swapped S15SR Z32 Swapped TT 1991Vert |
Crank/Oil pump collar sold to meeeeee ! ! ! ! ! ! Thank you zilvia i have scored in the last two days - everything i need.
Yeah, SLR. Kodak
![]() Thanks buddy! Thanks, let me know if you need anything else. Thanks for the purchase, let me know if you need anything else.
PM me for s13 or s14 parts! |
#17 | |
I sent your more info, let me know if you want it. I do have a crankcase breather, send me an offer.
