I've got an 240sx hatch with a blacktop sr20det....last night it wouldn't start. Cranked it for a while and tried a few different things and no dice. Pulled the
fuel pump fuse and cranked it just in case it was flooded and it started right up, put the fuse back in and it drove normal all the way home. Now it wont start unless you pull the fuel pump fuse and crank it a few times then replace the fuse and it runs. I don't want to drive it until I know what the problem is....ill pay some one to fix the problem......help will be greatly appreciated thanks
