fuel gauge ans speedo not working
im a little late on posting this but after doing my s13 sr20 swap in my s14 my gas gauge and speedo stop working. is this a common problem and is there a way of fixing it?
AFC #1
![]() Join Date: Oct 2003
What Lower/Transmission Harness are you using? Need to put the S14 VSS in the transmission.
#4 | |
AFC #1
You need to put the S14 VSS in the transmission line and get a S14 speed sensor harness/cable to run from the VSS to the fuse box. Should be able to harvest the black cable from your KA lower harness. If it was manual you can grab the VSS too. Auto has a different gear on it.
