Old 09-04-2009, 11:45 AM   #1
Ryokai Fuji
Ryokai Fuji's Avatar
Ryokai Fuji is an unknown quantity at this point
Send a message via AIM to Ryokai Fuji
Tempature Gauge in Dash
Hey guys im totally stumped on this one, Everytime I accelerate..
My Temp gauge meter.. Flies down to ZERO like Low..-- I let my gas go.. it will stumble to go back its normal stage.-
If I let the gas go and clutch go it releases, and then it comes back up faster then when I let go off the gas with the car in gear.
Any IDEAS???
Ryokai Fuji is offline   Reply With Quote
Old 09-04-2009, 02:52 PM   #2
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
Well A clue would be something about your temp gauge. It was quite hard to understand the post, a tip was "let my gas go" however Exibit 2b in the FSM shows the temp gauge is controlled by a sender next to the CTS. Its a 1 wire, using resistance to give a reading.
You have an electrical short, it should be the opposite of what your experiencing. A fun fact treat is when you decel, the temps will go down.
Bigsyke is offline   Reply With Quote
Old 09-05-2009, 12:34 PM   #3
Ryokai Fuji
yeah..^ haha... the temp stays down as the gar is still in motion.. haha.... looks like a video game... TURBO!!!! HAHA
*On a serious note.. is there a diagram where this is shown.
Old 09-05-2009, 12:37 PM   #4
blackrms13
blackrms13's Avatar
blackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfection
Send a message via AIM to blackrms13
did u try a new/different coolant temp sensor carlos?
91' 240sx Fastback LE
blackrms13 is offline   Reply With Quote
Old 09-05-2009, 08:46 PM   #5
projectRDM
projectRDM's Avatar
Ground the signal wire from the sender directly to the intake. What happens to the gauge? If it reacts the same, jumping and erratic, the gauge is bad. If it goes to one point smoothly and stays there, the sender is bad.
FORMERLY R240NA
