Old 06-05-2010, 10:35 AM   #1
DriftVader
DriftVader is an unknown quantity at this point
ABS Driveshaft Vs. Non ABS
Just a quick question. My S14 used to have ABS. But i've replaced the motor with a S14 SR and a Nismo 2 way diff that was NON ABS. Do I need to buy a ABS driveshaft or a NON ABS driveshaft for the car. thanks.
DriftVader is offline   Reply With Quote
Old 06-05-2010, 10:51 AM   #2
Sileighty_85
Sileighty_85's Avatar
The diff determines what Driveshaft you use.
so if you have a NON ABS Diff then you should use a NON ABS Drive Shaft
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 06-05-2010, 11:03 AM   #3
DriftVader
sweet figured as much but needd to double check and make sure. I thought maybe in some way if the car was ABS the diff sat up closer or something. dunno. thanks man.
Old 06-05-2010, 11:21 AM   #4
Sileighty_85
nah the ABS Diff is like 1 in longer so the ABS Drive shaft is 1 inch shorter
後輪駆動車1番
1986 SR86 - 200ish
