I heave a problem with my brakes
This started two days a go i turn the car of and my braake lights were on , so i check to see if mayve i left somthing on by mistake or somthing but no check my wiring to see if there were any crossd wires and no so now i have to be disconecting my battery every time i turn the car off if not my battery will die any help will be good, thanks in advanced
the beast is runing
i had the same problem last year. rubber plug fell apart behind brake pedal. inspect to see if its still there. check out this link =P WikiAnswers - Why wont brake lights turn off on a 89 nissan 240sx
