![]() Join Date: Jan 2003
![]() ![]() Feedback Score: 8 reviews
black top harness on a red top?
i looked around and searched but i didnt find much but for sale threads. can i use a black top s13 harness/ecu on a red top motor? i d assume i could if i change some sensors? but if there is a major difference let me know thanks?
![]() 1990 hatch ka24de gt2871r |
![]() Join Date: Jul 2002
![]() ![]() Feedback Score: 3 reviews
the plugs should line up but be sure to use a blacktop ECU as the pinout on the ECU side is different as for the o2 AFAIK the only diff is the thread size same voltage same o2 just diff threads
I never knew you could do that with an eggplant |
#4 | |
the harness is all the same , the only real difference in the ecu . I believe the blacktop had a different port on the head allowing for better flow , which is the only real difference between the motors and maybe the heat sinks on the head but its all fine i ran a blacktop with a redtop ecu at 9psi
Man w/ CTSV & a Car Seat
DEPENDS ON THE YEAR BLACKTOP. If you have the later version blacktop *97-98* Some of the pin outs to the ECU are different. 94-96 blacktops are exactly the same as the regular redtops with some difference but it wouldnt matter. You can interchange the E5 blacktop ecu and the 62(?) redtop ecu. The O2 sensor wouldnt matter either. You can interchange 02 sensors, only catch is you have to swap the turbo elbow too if you change 02 sensors between the skinny and fat ones.
