*Rebuilt* 0 miles CA18DET Swap + More CA spare Parts *Pics*
Hello,
I have a Rebuilt CA18DET, that I no longer have the time nor financial backing to finish the project. Its my loss your gain. Alot of quality parts were used during the build as no expense was spared. I've got 95% of the complete swap for a S13, missing small things like O2 Turbo Housing/Turbo Inlet/misc piping. Onto the CA18DET swap: Will come with 5spd Transmission,Clutch/Flywheel Driveshaft, SMIC, Piping, Turbo, Complete wiring harness with MAFS and ECU. Along with a 0 Mile CA18DET, which will require a Proper Break-in period. The following was done to the engine during the rebuild process. *Block hot-tanked/honed. Head resurfaced. 0mi since build. Rotating assembly coated with assembly lube during build. *Stock bore. *New Mahle Piston rings and Clevite rod and main bearings. *Cometic ML Headgasket *ARP Headstuds *Power Enterprise Timing Belt *New Timing Belt Tensioner *New Waterpump *Re-manufactured Oilpump *Full new factory gasket set. *Stainless Steel allen valve cover/cam cover hardware *Stainless Steel braided oil feed line. *Rebuilt T-25 with 0mi. *Bottom mount tubular manifold. *Turbo water feed block-off. Everything pictured below will be included with the CA18DET Swap. I am asking $1200 for the complete swap. Closer look at the engine ECU and Wiring Harness and MAFS Everything you get Last edited by kabukie; 10-09-2012 at 08:41 AM.. |
Here are my Extra CA18DET Parts:
Flywheel $30 Timing Covers $30 Valve Cover $20 Rear main Seal Holder $10 Coil pack bracket $10 5 speed Transmission brace $25 OEM Cam gears $15 each/ $20 for both CA18DET Alternator $60 CA18DET Starter $60 CA18DET Power Steering Pump $60 Coil Packs $15 each Coil Pack Harness $30 CA18DET Intake Manifold $60 CA18DET Rear Transmission Plate $30 CA18DET Block and Crankshaft and block girdle $150 Also have a Spare CA18DET Transmission in Great shape $150 *Will get pic if interested* Last edited by kabukie; 10-09-2012 at 08:43 AM.. |
![]() Join Date: Apr 2008
Oh man this is just what I need. How much for the long block with intake manifold and transmission, but minus exhaust manifold and turbo and harness and ecu and such shipped to 95476? I just blew mine after about 4 loving years with it so if I could just buy the longblock and trans it would be much appreciated.
#6 | |
I was wondering if you have the vacuum canister and silenoid for the butterfly valves available. Right now im running mine blocked off which leaves them fully open since i dont have those parts and im interested in getting it setup the right way. I heard it increases throttle response quite nicely.
I might also be intersted in the spare block, intake manifold, tranny ans a few other things im located in south florida so i would come pick them up. Lmk via email [email protected] or txt me at 954-815-6568 Last edited by CaDet S13; 09-11-2012 at 05:21 PM.. Reason: needed more info up |
Very good deal also CA's have a pretty big fan base here in Florida don't know what that guy is talking about not being popular.
Being a Floridian is a birth right! |
i want ittttttttttttt, if you werent so far i would offer you my running coupe for the swap+help to install motor in my vert.
I will give you my pistol ammo at the speed of light towards your doom
#17 | |
#18 | |
I would prefer to sell it together since the block and main caps and crankshaft should go together to the same buyer. But due to the lack of interest and the need for my storage space back, I would be willing to part with them. I could do $215 shipped for the items you asked for. LMK |
#19 |
#21 |
#23 |
text me about the power steering pump if humidle doesn't get it. i have cash in hand right now! i need this pump asap!!!! shipped to 81007 cash in hand. lol i just need this baddddddd 719-369-1821
#24 |
#27 |
#30 |
