![]() Join Date: Apr 2011
I should be getting my order of arms for my s14 pretty soon, but i was wondering whats the best suspension tune( camber, toe, caster,ect..) for drifting. Currently im running a stock KA, since i just started drifting like 3 weeks ago i dont plan on getting a lot of power, yet.
my car currently has: rebuilt j30 vlsd 1 piece lightweight driveshaft Stage 2 clutch with 14lb flywheel short shifter alum. 2 row radiator with slim electric fans. kyb shocks with lowering springs( lower about 2 inches) godspeed gen2 rear toe arms in the process of a full interior gutout. My new order includes: godspeed rear LCA godspeed rear camber godspeed rear traction/tension rod godspeed front tension rod godspeed rear swaybar godspeed front swaybar As u can see im focusing on suspension over power upgrades for right now. My question is, after i install all of these what adjustments should i make from the stock alignment that would help for drifting?
it all depends on what you like, theres really no set tune for it
search around, theres a lot of threads about setups find a good base setup and then mess around with it until you find what you like
'92 240sx w/'93 SR Blacktop /// '94 RX7 FD3S /// '11 370z RIP |
