All 4 wheel bearings on my car were just about shot. I happen to be an employee of advance auto parts so I looked them up and came to one single listing for a Beck/Arnley unit. I purchased 2 with my lovely employee discount (20%) and proceeded home to remove the hubs. Took both hubs and bearings to a local machine shop to have them pressed in and learned the wonderful news, not only could they not press out the old bearings, but the new ones were far too big for the hubs.
So I start researching only to find that the hubs are two very different units. What makes this all so wonderful is that there was absolutely no mention of any differences in designs on APAL. (advance's parts lookup program) I'm going to contact corporate Monday and explain the error, as well as inform Beck/Arnley of the mistaken listing. So now I'm guessing the Non-ABS hubs are a one-piece design which leads me to a question, where do you get these things for a decent price? I've seen shitloads of S13 5-lug conversion hubs but when you hit S14, it becomes a gray area (at least in my opinion it does.) On a side note, Autozone's price on my back bearings was less than advance's after my 20% off. Just some info for us guys too poor to run racing grade bearings.
xIan.M.x-"That car makes me feel naughty, like an 11 year old watching scrambled porn." Last edited by trey21096; 07-18-2009 at 01:54 AM.. Reason: Added pics |
![]() Join Date: Dec 2002
Welcome to Earth. It's been common knowledge since 1995 that the S14 front wheel bearings are NOT replaceable. They're a one piece design with the hub. The entire unit is replaced as a whole if the bearing is bad. This is true for both ABS and non ABS models.
The dealer. That or any of these eghey specials. It's called a hub.
So basically what your trying to say is that all the major aftermarket OEM replacement manufactures like Timkin, Beck/Arnley,etc. with all the of their research and product knowledge are making a part that doesn't exist? The Beck/Arnley part no. is 051-3997 and it IS a replacement bearing FOR an ABS hub.
xIan.M.x-"That car makes me feel naughty, like an 11 year old watching scrambled porn." |
#8 | |
FYI, the bearing portion is the exact same for both ABS and non ABS anyway. The only difference is the ABS hub has the ABS ring on it. You can use either hub on a non ABS car fine, the bearing doesn't matter.
s-14 hubs
Home Log In Your Account Catalogs Auctions Shopping Cart Order Status Contact Us Policies p.{margin:0in;margin-bottom:.0001pt;} .mainCatNum{ color:white; font-size:10pt; border-right:1px solid black; background-color: Gray; } .mainCatText{ color:Black; font-size:10pt; background-color: #EEEEEE; } .notes{ color:Black; font-size:8pt; background-color: #FFFED9; } a.notes{ color:Blue; font-weight: Normal; font-style: Normal; font-size:8pt; } a.notes:hover{ color:Red; font-weight: Normal; font-style: Normal; font-size:8pt; } .radio{ font-size:8pt; background-color: transparent; } Mechanical Catalog Front suspension , Suspension components ,Front hub 1996 Nissan 240sx Alternator Automatic transmission Body hardware Brakes Clutch Cooling system Electrical Emission system Engine Exhaust system Front suspension Crossmember Lower control arm Lower control arm Stabilizer bar Stabilizer bar Suspension components Bracket Coil spring Front hub Knuckle Spring seat Strut Strut mount Tension strut Fuel system Hvac Maintenance & lubrication Manual transmission Rear suspension Starter Steering Steering column Universals & rear axle Keyword or Part Number DescriptionYearMSRP PriceCore PriceYour PriceFront hub, 240sx, standard, w/o abs 95-98 $147.67 $118.14 |
Ok, I admit my mistakes on this, but now I have a brand new problem. I'm in the middle of removing the spindle. The problem is, I can't get it to come off the lower ball joint. Please dear god tell me it's not pressed on there too. I know the ball joint is pressed into the control arm, but is the steering knuckle pressed on too.
#11 | |
You can also beat it out with a hammer if you're replacing it.
