5.0L in S13
whats up guys. im about to start my new swap. im putting a 5.0 in my 240 and i have no idea what to do about mounts. like the motor and tranny mounts. any ideas please respond
On the 8th day god created DRIFT!!! |
.com
I'm doing a 5.0 in an FC, and I really wish I'd have done an LS. I'd be done instead of dealing with about a billion issues that others have already solved with LS swaps. If you can't make your own mounts, about the easiest part of a swap, I'd really consider doing the LS as it's far better mapped out. Your kind of on your own in using a 5.0, as on most swap forums when you ask a question on how to do something everyone asks "why didn't you use an LS?". So I'd say bone up on your fabrication skills and be prepared to make a bunch of stuff for yourself, or do an LS. Not trying to dissuade you, just be prepared to work out problems on your own solution instead of buying something worked out, because there's really no swap kits out there.
