6' 2" and i need a racing bucket.
im in the market for a cheap bucket seat that will hold me in place. my budget is $500 for a seat and sliders or mounts. i have harnesses.
my delema is i've been searching for a couple weeks on how i can get a seat to sit low enough to clear my helmet. there are others who have posted this similar questions but no one seems to give a budget-friendly setup or even definite specs are rare. im obviously going to need a side mount bucket. who makes a cheap one? im not worried about getting a brand name seat, i just want something that works. also, what rails do i get? i know i'm going to need to bash down the catalytic converter tunnel. i need more insight so i can narrow my search. |
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
Custom bracket with whatever seat you find that fits you. None of the off the shelf brackets
I have a sparco evo 2 plus, and I've also had regular Sparco Evo 2. The wider seats don't work with the off-the-shelf brackets (bride, nams, nagisa, buddy club). |
![]() Join Date: Jul 2007
Trader Rating: (106)
The "Planted" seat brackets are the lowest that I have ever seen by far. Get the low model and run it without any sliders. As for a seat, your budget is small enough that used is your best option. I wouldn't buy any racing bucket that wasn't FIA certified originally at least...
Definitely not get the aftermarket slider seat rails they will not fit any large sized bucket seat. I have an evo 2 seat with buddy club sliders and my head literally are an inch away from the ceiling with the cushion taken out. Im only 5'10, and im forced to find a shop to make me a custom seat bracket.
Why is everyone talking abotu wide buckets? I've read the OP like 4 times looking for where that was mentioned.
I have a wedge bracket with recaro sidemount brackets on my sparco pro 2000. I cut out the center of the seat bracket in the rear to lower the seat more. I am just under 6ft tall and i can stand my hand up on top of my head and still have room to move it up and down (about 1/2"). My buddy got the planted super low brackets. His seat interferes with the front sidemount bracket so he's still one level up from the lowest. I have about 1/2" more room on top of my head with his setup than mine. With a different seat he could lower it even more. His setup is the first that I have ever sat in that actually feels like it's as low as the stock seat. I have sat in a LOT of different setups. Nagisa, Bride, and Buddy Club don't even come close. Remember though that we are running without any sliders. From my experience that's the ONLY way to get the seat even close to as low as the stock one... |
#8 | |
Bride low max v2 with cushions. If you take the cushions out you will obviously be lower |
![]() Join Date: Jan 2010
Trader Rating: (26)
Willing you aren't tall and fat, you could probably fit in any seat out there comfortably. From there, you can either make custom brackets or custom mounting points and go from there.
![]() Join Date: Mar 2008
You don't need to be fat to need a plus sized seat, At 6'5" my shoulder blades hit the beltholes on some seats, and the bottom of my helmet can catch on the top of the seat.
My Profi XL is 2" taller and has raised belt holes
Trader Rating: (24)
That's why I have an evo 2 plus -- taller backrest, and the seat itself is narrower than the evo 2 by a little bit. But it's still too wide to fit on off-the-shelf rails.
cut the hump out from under your seat, weld in your own bracket to the floor, and then you will have a 4" drop....... you can run any seat you want and have clearance......
im 6'4" and with a side-mount bucket seat the top of my shoulder sits at the top of my door and I have at least 3"+ of room above my helmet.... |
![]() Join Date: Sep 2010
I have the recaro spg seat using a nagisa bracket/rail combo. I modified the nagisa unit a little bit (rear mounts). Other than that I flattened the catalytic hump as much as I could. At one point my seat was comfortably on the floor board (without the stupid angle that most people have making your bucket look like a recliner). That was too low for me being 6 foot so I raised it up a couple inches. I would have had plenty of room for a helmet in both setups.
