![]() Join Date: Jun 2002
Trader Rating: (32)
![]() Feedback Score: 32 reviews
PARTOUT 1997 Nissan 240sx S14 95-98 Parts KA SR
Parting out 1997 Nissan 240sx.
******EVERYTHING MUST GO****** SE MODEL 5lug Complete interior available. KOUKI tails (Complete set) Bride Bucket Seat Ready to bolt on (s13/s14 240sx) NRG Quick Release HUB and Wheel Enkie Wheels 235/45/17 3" Dual tip Custom exhaust Welded diff J30 DIFF Driver side Windows switches Passenger side window switches Ac bezels Radio bezels Ash trays Ecu Kick panel Fuse box kick panel MANY more available.....just text and ask. S14 ZENKI cluster s14 Zenki Tails S14 Zenki Corner lights S14 Zenki Bumper turn signals S14 Kouki Cluster S14 to S14 SR20 Harness (notchtop) S14 Kouki Window switch (96 - 98) MINT Rear Subframe S14 SEATBELTS REAR S14 4lug HUBS (REARS) S14 Rear Knuckles S14 OEM floor mats S14 Throttle cable S14 gas pedal S14 blower motor S14 AC BOX S14 Heater Core S14 AC BEZEL S14 Glove box S14 A Pillars S14 interior harmess S14 SE WING (red, mint.) S14 Rear seat S14 Ebrake handle S14 ebrake cables S14 airbags S14 Dash Bar S14 Exedy Stage 3 Hyper Single Clutch Kit Hyper Single Clutch SR20 Stock manifold T25 inlet and outlet necks SR20DET Igniter 5sp cross member (S13/S14) 3C ECUs (S14 5sp) S13 ecu ka24de S13 headlights S13 driver side window switch (RHD switches) Tons of parts LMK what you need. working on updaing with pics PauL 917655811four TEXT FOR FASTEST RESPONSE. |
![]() Join Date: Jun 2006
I need the ac trim with defrost and blank butons
Also need the: clutch rubber stopper that hits safety switch Nut that hols down ecu kick panel or fuse panel cover interior door trim cups uncracked Screw covers that go into the door pocket where you pull to close the door Interior seat mount covers electric antenna assembly Let me know, |
