![]() Join Date: Mar 2009
S13.5 headlight/turn signal conversion harness.
I have a spare s13 headlights / turn signals to s15 headlights / turn signal harness. no wiring or modifying your existing wiring or the plugs on the S15 headlights needed. Just plug in and play. $150 shipped. I Also have a small supply of spare hard to find s15 turn signal plugs (3 pin), and low beam plugs (2 pin).
Bump, If any one is doing this conversion on their S13, these will remove all the guess work for you. Not to mention the 3 pin plug for the Turn signal and running lights are almost impossible to find. Speaking of which If you are just interested in just the 3 pin plug I can get you a pair. PM me for details.
I can make more conversion harnesses for both S13's and S14's. Or I can sell you all the plugs you will need for you S15 headlights and you do the wiring. I will ship where ever. PM me for details.
I can make those too. I will send you a PM
Do you need; Right side (USDM Passenger side) Replica S13 OEM Silvia Aero Bumper Grill S13 Silvia J's, Q's, K's, A's Bumper grill inserts. Male Plugs for S15 headlights PM me if you need them. |
